Rubicon Express Long Arm Kit - JeepForum.com
post #1 of 8 Old 08-28-2007, 09:36 AM Thread Starter
ADRC
Does anyone else have any experience with the rubicon express long arm kit? I have had mine in for a couple of months now and when I drive it for a while I start to get a bad creaking noise. I have greased the heims and used silicon lube on the bushings and no change. I cant isolate the noise because it resonates through all the unibody. Any tips would be super I am at the point where I am about to bust out the welder and weld all the mounts to the unibody.
ADRC is offline
post #2 of 8 Old 08-28-2007, 10:07 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i have herd similar things about a few other long arm kits, mabe its along arm thing??
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 8 Old 08-28-2007, 10:35 AM
micifus
Original GC'er
micifus's Avatar
I would put the jeep up on jack stands and jack up the axle then let it down see if you can reproduce the sound that way maybe?
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #4 of 8 Old 08-28-2007, 11:25 AM
RyanZJ
RyanZJ's Avatar
My buddy had RE LAs on his XJ and they were always making squeaking noises. He was never able to slove the issue.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #5 of 8 Old 08-28-2007, 01:27 PM
DeV
Thats what you get when you lift a jeep. Some jeeps are groaners and some are quiet. Mines noisy as hell.
95 Green ZJ
3.5 IRO
32x11.5 Pro Comp MT's sittin on 15x8 rock crawler
JKS Quick Discos
DeV is offline
post #6 of 8 Old 08-28-2007, 05:43 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Have you greased all the bushings on the control arms?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 8 Old 08-29-2007, 10:39 AM Thread Starter
ADRC
I have greased everything, I used a silcon grease on the rubber bushings and full synthetic on the heims and the noise is still there. The noise is only there after driving a while. It doesnt make a noise when I first drive it. I think that it might be the LA brackets causing the unibody to flex?
ADRC is offline
post #8 of 8 Old 08-29-2007, 11:16 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The subframe shouldn't be letting the unibody flex that much.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
Rubicon Express or IRO jeep360limited ZJ Grand Cherokee Forum 5 09-22-2009 02:43 PM
Rubicon Express LCA bushings shadetree ZJ Grand Cherokee Forum 4 07-23-2009 11:53 AM
Rubicon Express LCAs? branman444 ZJ Grand Cherokee Forum 12 02-07-2006 03:43 PM
My ZJ with 3.5" Rubicon Express Kit Phil Gerard ZJ Grand Cherokee Forum 15 03-06-2005 11:50 PM
Rubicon Express is down... KillerZJ ZJ Grand Cherokee Forum 1 07-20-2003 12:36 PM
