rubbing sound when turning wheel - JeepForum.com
post #1 of 11 Old 09-06-2003, 01:22 PM Thread Starter
pygocentrus
when i turn sharply or do a U-turn, it vibrates and makes alot of noise. at first i thought it was the tread on the tires, but im not sure. the tires are stock size, not big.
pygocentrus is offline
post #2 of 11 Old 09-06-2003, 02:43 PM
Harald
What car?
Could be visco-coupling in transfer gear as a guess...
Harald is offline
post #3 of 11 Old 09-06-2003, 02:59 PM Thread Starter
pygocentrus
its a GC 98 5.2 liter
should i ask my dealer to look at it? i bought it a week ago
post #4 of 11 Old 09-07-2003, 05:22 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Pygo,
I wouldn't take it to the stealership unless you just had too.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 11 Old 09-07-2003, 10:07 AM
Stocker
If you bought it last week, there should be some warranty coverage on it. If so, IMO take it back - it could be a costly repair - viscous coupler in t-case, or cv joints in front axle are possibilities.
If it occurs only after drivetrain is warmed up, suspect the t-case.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #6 of 11 Old 09-07-2003, 11:23 AM Thread Starter
pygocentrus
it happens 100% of time i do u turns or park 90 degrees
post #7 of 11 Old 09-07-2003, 02:13 PM
Stocker
Since it does it when cold, probably not t-case (good news!). Take a good look at the cv joints.
Stocker
Stocker is offline
post #8 of 11 Old 09-07-2003, 04:02 PM Thread Starter
pygocentrus
what am i looking for? i dunno about parts and stuff, but if you tell me if i can fix it myself, im willing to learn.
post #9 of 11 Old 09-07-2003, 08:35 PM
Stocker
Basics - cv joints are the flex joints (similar in function to u-joints) that are at the outer ends of the front drive axle. They transmit power and allow the front wheels to turn. There is a rubber boot over each, and it may split open, allowing grease to escape and all kinds of crud in, contaminating the joint and causing premature failure.
I found this old thread which primarily discusses replacing the boot, but also mentions replacing the half-shaft (assembly includes the cv joint). If you need more info, and don't get enough in this thread, try the search feature, and maybe try to contact JEEPTECHNICIAN, a member here who posted in this thread http://www.jeepforum.com/forum/f13/cv-driveshaft-boot-torn-42526/ .
Good luck!
Stocker
Stocker is offline
post #10 of 11 Old 09-08-2003, 01:37 AM Thread Starter
pygocentrus
is it hard to replace and costly for parts?
i can get parts real cheap, but is it something anyone can do?
post #11 of 11 Old 09-08-2003, 11:17 AM
automan25
rebuilt CV shafts (The half shaft + the CV joint) cost around $120 each. There are very easy to replace, though you may need to buy a giant socket and a really long breaker bar to get the hub nut off. You'll need a 250 ft/lb torque wrench as well. Do a search and see if you can't find a detailed posting on the entire process.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
front left wheel wierd sound when turning and clicking when driving ChickenOnAWire ZJ Grand Cherokee Forum 2 08-27-2009 12:13 AM
Rubbing when Turning 98zjteen ZJ Grand Cherokee Forum 8 11-05-2008 04:59 PM
Rubbing Sound...Help JFox21 ZJ Grand Cherokee Forum 1 11-03-2007 01:08 AM
rubbing (reverse + turning) JeremyBelnap ZJ Grand Cherokee Forum 13 12-19-2006 10:00 PM
rubbing sound?? errodri1961 ZJ Grand Cherokee Forum 3 02-25-2003 10:05 PM
