Rubbing - JeepForum.com
post #1 of 19 Old 05-02-2013, 06:18 PM Thread Starter
KyleD31
Rubbing
I just put a 2" BB on my 93 zj and put 31s on. I didn't trim anything. When I turn I rub on my front bumper. I thought I didn't have to trim. How do I fix this?
KyleD31 is offline
post #2 of 19 Old 05-02-2013, 06:21 PM Thread Starter
KyleD31
I only rub on the bottom corner, just a little. How would I go about removing that section?
KyleD31 is offline
post #3 of 19 Old 05-02-2013, 06:27 PM
JasonStebbins
Use a pair of snippers or a box cutter. Goes right through the rubberized plastic. Unless you have the hard plastic? If so I would use a dremel.
I trimmed my front and rear bumper cover up to the first "line" where it concaves. Looks good and gives you extra clearance.
Most 2" boosts are actually 1.75"
Did you also replaced the isolators?
Poop
JasonStebbins is offline
post #4 of 19 Old 05-02-2013, 06:51 PM Thread Starter
KyleD31
I extended my front bumpstops. That's it. I'll try a box cutter I guess. I want to trim the same amount you did, but I dot want it to look bad.
KyleD31 is offline
post #5 of 19 Old 05-02-2013, 08:18 PM
AnotherRedZj
I put a 2.25 BB in mine with 31's kept the isolators. Had to cut about 1.5" to nothing wedge from the inner bottom corner to clear the bumper, no more rub. 2 washers in the steering stops keeps the control arms free from rubbing too, with stock larado rims that is.
AnotherRedZj is offline
post #6 of 19 Old 05-02-2013, 08:30 PM Thread Starter
KyleD31
I just trimmed an inch and a half of the bumper. It seemed to be my only option. It doesn't look bad. I have to take pictures in the day light
KyleD31 is offline
post #7 of 19 Old 05-03-2013, 08:52 AM
PolkaPower
I had to trim the corners off of the inner part of the front bumper with a dremmel. Took 5 minutes.
PolkaPower is offline
post #8 of 19 Old 05-03-2013, 09:33 AM Thread Starter
KyleD31
KyleD31 is offline
post #9 of 19 Old 05-03-2013, 10:15 AM
PolkaPower
I didn't have to cut that much at all. Just this little corner.
post #10 of 19 Old 05-03-2013, 10:27 AM Thread Starter
KyleD31
I think we trimmed a little extra, but I think I still would have rubbed of I only trimmed that much. I'm not sure
KyleD31 is offline
post #11 of 19 Old 05-04-2013, 12:36 AM
Candymancan
im suprised with a 2 inch boost you have to trim with 31's. I had to trim on stock height with my 30.5 inch tires.. i wouldnt think youd have to do it with 2 extra inchs.. maybe your springs are really saggy
Candymancan is offline
post #12 of 19 Old 05-04-2013, 12:58 AM
Joeyicu
Joeyicu's Avatar
I am not. I am at 3.5" and I still rub on my stock LCAs when at full lock reverse. that is a 245/75R16 witch is a 31x10.50 16 basically. That is on stock rims though, so it tends to make a difference with different backspacing.
(2011 BMW X5 V8TT) {2005 WK Hemi } -1995 Ford Tbird- [1984 F250 6.9]
Joeyicu is offline
post #13 of 19 Old 05-04-2013, 05:43 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Wheels with 3.75 to 4 inches of backspacing won't have tire rub.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #14 of 19 Old 05-04-2013, 06:38 AM
98LIZJ
I have a 2" BB with 31x10.5x15 with 4" backspacing and I rubbed a lot before I cut my bumpers
98LIZJ is offline
post #15 of 19 Old 05-04-2013, 07:38 AM
um7267
sawzall with a fine toothed blade works well fro cutting plastic bumpers, or one of the mini ones with a 6 inch blade they run 30 bucks from sears or whatever but they do have many uses
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
