Rubber freeze plugs? - Page 2 - JeepForum.com
post #16 of 49 Old 02-09-2010, 12:59 PM
22remud
Yea the freeze plugs are actualy for casting purposes to romove excess sand after the casting problem, as well as for when your motor freeze they are suppose to pop out. But sadly most METAL ones seize and corode or rust, and don't do there job. Which is why they have rubber ones. If installed corectly they do there job. And in your case usualy if a motor over heats the holes where the freeze plugs go sometimes warp. So rubber is usualy a better idea. I've installed them in a few motors and never had an issue. And for those who commented saying they should have freeze plugs to fit it, that is wishfull thinking on your part I run a fleet and when it comes to older vehicles it's is extreamly hard to get such specific parts alot of times. Which is why they make ruber expandable ones.
1998 TJ 4.0L NP231, 4inch skyjacker kit
1992 XJ 4.0L NP231, 6inch Gonzo Lift, Cherry Bombed Exhaust,Custom Cowl Snorkel,33x12.50 BFG km m/t's
22remud is offline
post #17 of 49 Old 02-09-2010, 04:01 PM
RyanZJ
RyanZJ's Avatar
I replaced a leaking freeze plug with one of the rubber ones recently, due to the location being really tough to re-install an OE metal one. The rubber one now leaks worse than the corroded metal original one. My jeep has been sitting for 2 months now, often times in single digit temps, and I don't think it has much in the way of coolant left in it. It's all over the parking lot instead...
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #18 of 49 Old 02-09-2010, 04:48 PM
longboy
2006 WK
Originally Posted by Mike1084 View Post
I used rubber freeze plugs, (expansion plugs), in a 350 SBC when I lived in Colorado. Never had a problem. They hold up just fine.
I used one on my CJ's old engine here in Colorado. Tightened it up about 6 months after installing it, but never had any issues.
It was either that or remove the following to install a brass one:
-steering column
-intake manifold
-exhaust manifold
I took the route that took about 2 minutes and have no regrets.
2006 5.7l WK
longboy is offline
post #19 of 49 Old 02-09-2010, 04:52 PM
sdowney717
I have seen the nuts rust so maybe good idea to oil the nut & bolt before you put it on. Then you can tighten later. It is like a rubber hose, clamps need periodic tightening. likely same with rubber plugs.
sdowney717 is offline
post #20 of 49 Old 02-09-2010, 04:56 PM
Silverton34
They are casting plugs, the term freeze plug was coined by an extremely lucky idiot.
Silverton34 is offline
post #21 of 49 Old 02-09-2010, 06:37 PM
22remud
Well they call the plugs freeze plugs for there purpose of being there. And the whole is actualy a casting hole for wash out after production of the block
22remud is offline
post #22 of 49 Old 02-09-2010, 06:48 PM
chicagoanalog
JK Wrangler
-steering column
-intake manifold
-exhaust manifold
Granted, I live in Chicago proper so it's not just the cold I have to contend with, it's the salt as well. All the same, the rubber was completely corroded. From the outside it looked like it was installed properly and was even a PITA to remove the leaking rubber plug, once I got it out I could see where the rubber had just completely eroded. I don't know who did it, or when it was done, so consequently I don't know how long it's held up (for all I know it could have been 10 years). All I know is that every other plug was OEM steel and holding up fine. The only one that leaked was this rubber plug. I'll stick with brass.
chicagoanalog is offline
post #23 of 49 Old 02-09-2010, 07:01 PM
22remud
It's a personal decision
22remud is offline
post #24 of 49 Old 02-09-2010, 09:04 PM
ponytail77
where i live it gets pretty cold. can get down below zero here. i had a full size chev. truck once where the freeze plugs rusted holes in them from previous owner lack of antifreeze. i replaced the ones i could with steel and one in particular was very hard to get to so i replaced it with a rubber plug. it was supposed to be a temperary fix until it came loose but it never did. three years later i blew the motor but that plug stayed strong with no leaks. i personally say they work.....they dont cost much.......and in a pinch are a very hard to get to spot they work. but on the other hand i did that to my own truck. would not expect that from a shop......
ponytail77 is offline
post #25 of 49 Old 02-09-2010, 10:31 PM
KJK
As posted before, "freeze plugs" are metal discs used to seal the holes left by the casting process to hold the engine cores in proper alignment. They will not protect a block from cracking due to freezing temperatures.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #26 of 49 Old 02-10-2010, 12:13 AM
22remud
that is one of there functions is to pop out when the water frezzes In a motor. I am a ASE certified mechanic and run a fleet of 47 vehicles so I'm pretty sure I know what they are there for.
22remud is offline
post #27 of 49 Old 02-10-2010, 07:34 AM
Silverton34
Being a boater I have seen quite a few engines that were not winterized correctly and the water in the block froze. Once in a while the casting plug will push out without cracking the block but it is certainly not common. I am amazed at the sheer number of people who actually think this was part of the design of the block.
post #28 of 49 Old 02-10-2010, 04:04 PM
KJK
Like they guy above you...Lol.
KJK is offline
post #29 of 49 Old 02-10-2010, 05:45 PM
thebgkoolio
someone please show me where car manufacturers actually say they make these "freeze plugs" for keeping an engine from cracking? they are designed for casting purposes only and though they work to keep the block from cracking they are not designed for this purpose. if they didn't need the "access" holes in casting there wouldn't be any holes like that on the block. and not to poke back at other users but I am also a ASE certified technician, I have a degree in automotive technology and have done a fair share in machine shop work.
back on topic
never heard of rubber ones but I guess they work. would use them in a pinch if I needed too.
13 JKU -33's, afe exhaust, more to come
Sold: 94 zj -3.5" on 31's, bunch of other mods.
thebgkoolio is offline
post #30 of 49 Old 02-10-2010, 07:16 PM
22remud
Well I suppose that's the difrence in were you learned what you did. Just because you never heard of them being used or designed in for that purpose doesn't mean it isn't true. It just means you are un aware and not wanting to accept it as a truth.
22remud is offline
rusted out freeze plugs Stuart ZJ Grand Cherokee Forum 5 03-18-2011 08:09 AM
Freeze plugs CaseyC ZJ Grand Cherokee Forum 0 09-05-2009 09:25 PM
freeze plugs 5.2 wightkliff ZJ Grand Cherokee Forum 1 06-15-2009 11:10 PM
freeze plugs xj 98/yj 94 ZJ Grand Cherokee Forum 12 10-15-2007 08:34 PM
What size are freeze plugs for a 97' 5.2? kjopen ZJ Grand Cherokee Forum 4 09-29-2007 10:12 PM
