rpm's going up & down - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > rpm's going up & down
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 08-12-2012, 08:32 PM   #1
jr4x4
when in park & i slowly rev engine once rpm's hit 3,500. the rpm's will swing back & forth from 3500 to 3000 when holding steady throttle. this dont happen at any other range under or above. i just replaced tps a month ago. engine seems to have a little stutter to it. aic is fairly new. could this be cam or crank sensor starting to go?? everything shows fine on my obd scanner, all monitors show good. i cant find nothing in the search. thanks guys
jr4x4 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 08:59 PM   #2
sevenscrew
read my threads on idle problems recent couple pages I think.
I replaced my tps a month ago too. I'm having a up down rpm random hot or cold I think, and it spikes when switching to park and drops to 300 in drive.
going to check my iac for dirt. then replace the tps under advanced auto warranty
1997 Limited 5.2L Nelly - SOLD
1997 Limited 5.2L - new project
sevenscrew is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 09:11 PM   #3
ZeeJay1997
I'm not sure where i read it, but I know I read that holding over 2500 with no load can damage the engine. I'm sure someone is going to beat me up and tell me I'm wrong, but what the hell...
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2012, 09:22 PM   #4
jr4x4
its not something i do alot.lol. i was troubleshooting some stuff & noticed it
Unread 08-13-2012, 11:37 AM   #5
jr4x4
ok. i replaced tps sensor (mopar) & its still doing it . my scanner is saying all monitors are ok. except i noticed it said o2 sensor heater is incomplete. but says o2 sensor monitors are ok,evap monitors ok everything ok but o2 heater. and also now if i crank engine real quick but dont start it it will like blow a rush of air out throttle body. like (swuch). engine idles fine except what feels like a little stutter. the back & forth rpm's only at 3500 holding steady throttle the tack will go up& down 500 rpm's. almost like a rev limiter. almost like toming is off. scanner says adv.ign. is like arund 17 degrees at idle. & will go up as much as 40 degrees when driving. i had the pcm reflashed last year as a recall. i feel like they messed something up. since then i cant fix or find this tink/clinking noise at idle sounds like bellhousing but with stethascope the clink sounds real hollow metallic right around base of oil dipstick tube where it goes into block. i some how feel this is all related. so what do ya guys think.LOL.... by the way. THANK YOU ALL..
Unread 08-13-2012, 12:08 PM   #6
sevenscrew
not sure but until someone else replies, check underneath to make sure the o2 sensor wires arent burned
Unread 08-13-2012, 07:26 PM   #7
jr4x4
yea i did that today & checked them both with multimeter & their fine. there NTK & 1 year old. oh & as far as rpm's going up & down i swapped out my aic with one i had laying around & the problem is like 90% gone. but still there
Unread 08-13-2012, 07:43 PM   #8
sevenscrew
ok heres what mine does, if its going up and down in park(like today, AFTER cleaning the iac, made no difference) if i step on the gas quick to 3k and let off real quick itll fall to 1k then stop, then fall to normal idle around 6-700 ish in park and not surge.
Unread 08-13-2012, 11:18 PM   #9
jr4x4
that ^ might be your aic. my rpm's hold steady everywhere except at 3500. if i try holding throttle steady at 3500 the engine will rev back & forth from 3500 to 3000 back & forth over & over. but only at that spot.
