-   -   RPMs bottom out on decel (http://www.jeepforum.com/forum/f13/rpms-bottom-out-decel-1515375/)
thebean04 04-27-2013 03:14 PM
Hello all. First time poster here. So I apologize if this is an old, worn out question. Couldn't find much on a search though.
So here it is: I've noticed that when coming to a stop, my '93 ZJ 4.0 will drop down to like 200-300 rpm, causing a stall out or near stall. Seems idle fine in park, only does this when coming to a stop.
Not much of a mechanic here, but really hoping to get into doing my own auto repairs/maintenance. Ay suggestions on what might be going on or a good place to start looking?
youlost2melol 04-28-2013 06:17 AM
I had the same problem try cleaning your IAC valve. I had a 5.2 mine was behind my throttle body. yours should be either there or on the side of it
JeepNicholson 04-28-2013 12:19 PM
x2
I just did this a few days ago after stalling coming up my driveway and idle so low my engine wouldn't stay running without me gassing it. Cleaning took about 5 or 10 minutes with some carb n throttle body cleaner, believe the screws came out with a Torx bit but the size I can't remember, mighta been a T20. I cleaned the throttle body while I was there and also cleaned out the little channel that leads into your throttle body from the IAC.
After an initial rough start and a bit of white smoke which I suspect was from the carb cleaner, my Jeep now idles smooth and doesn't struggle to stay awake.
thebean04 04-28-2013 04:17 PM
Thanks for the info, guys! Picked up some carb cleaner and would love to get this fixed today, but it is pouring rain in AL today and I am working out of an uncovered driveway. Will give this a shot tomorrow. High hopes for a good outcome!
thebean04 04-29-2013 09:39 AM
Was able to get around to it last night. Was only able to clean the IAC valve, though, haven't cleaned any other thottle components yet. Seems to have make a big difference, though. Super steady on decel this morning. That thing was GUNKED UP! Thanks again for the help!!
JeepNicholson 04-29-2013 04:43 PM
Nice! Gotta love those easy fixes!
The time now is 07:49 PM.
