RPM matches MPH while coasting - JeepForum.com
post #1 of 9 Old 09-13-2009, 01:23 PM Thread Starter
proffessor
97 Grand Cherokee LTD / 318 1/st Jeep
Problem: The engine RPM matches the MPH when in OD or even in neutral when coasting. Tested on hill in neutral and 65mph =2,000 rpm.
I have disconnected battery and had it idle down the first time I tested it , then it quickly goes back to matching the mph. Tested #3 times; twice with battery and once by clearing with code machine (no codes)
In the test with the code machine it never idled down even on the first try.
Seems to drop to idle ramdomly below 30mph.
proffessor is offline
post #2 of 9 Old 09-13-2009, 01:26 PM
SILASPRIT
might try replacing your IAC (idle air control) or your speed density air sensor.
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
post #3 of 9 Old 09-14-2009, 09:09 AM Thread Starter
proffessor
Hey Silas; thanks for the answer. Like I said tho, 1st jeep ... where are they & what do they look like?
are they cleanable? **** could you point me at an IPB?***
I am on a fixed income and cannot troubleshoot by replacing parts.
post #4 of 9 Old 09-14-2009, 09:16 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Sounds like its just not down shifting when it should. Check your Transmission fluid levels (on level surface, engine running and to normal operating temp, in neutral.) Could be a speed sensor, or governor pressure sensor in the transmission. If the fluid looks ok (level, color, and smell) I would take it up to a tranny shop.
~James
ezflip is offline
post #5 of 9 Old 09-14-2009, 04:41 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's normal, the computer doesn't know it's not in gear and is matching idle input to what would be needed with a load on the engine at that speed.
also, since your torque converter is locked up in overdrive at those speeds, the engine rpms will NOT drop with letting off the pedal, they will drop with vehicle speed untill the torque converter unlocks and allows variation between the motor and the transmission.
ratmonkey is offline
post #6 of 9 Old 09-14-2009, 04:53 PM
MurdaJs
My jeep doesnt do that when in neutral going down a hill.
MurdaJs is offline
post #7 of 9 Old 09-15-2009, 06:02 PM Thread Starter
proffessor
Murda... you're right! thats' the beauty of a Mopar type trans ! when you let off the gas; engine rpms drop to nothing & you save fuel. My daughters' '97 drops to idle and millage on the VIC goes to 99 if you are above 50 mph. She has the 6 cylinder tho. SO, if the V-8's are not a totally different acting system I still have not gotten a specific solution.
I have been studying and found that the throttle position sensor on the V-8s' is a dual sender and signals both the engine and transmission. Has anyone out there had the same problem and found the TPS to be the cure?????
post #8 of 9 Old 09-25-2009, 04:40 PM Thread Starter
proffessor
Update: I cleaned the IAC and the RPM's dropped correctly the first 9 mile trip over & down the mountain. When I started to pick up speed the trans even kicked in with a slight hold-back and just a little increase in RPM. Perfect! On the way back same old ****; RPM matched MPH. Don't know if it was the cleaning or disconnecting the battery that did it.
Does anyone know what Silas means by "speed density air sensor"? It's not on my Electronic engine control component locations chart.
post #9 of 9 Old 09-25-2009, 10:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Map sensor. Manifold absolute pressure. We don't have speed density/mass airflow units.
98 ZJ vibes at hwy, worse while coasting RobinsonFam1 ZJ Grand Cherokee Forum 3 11-30-2009 12:26 PM
Noise when coasting surfratjeep ZJ Grand Cherokee Forum 4 10-30-2009 09:41 AM
horrible hum/vibration while coasting sullivanpunk ZJ Grand Cherokee Forum 6 10-19-2009 09:59 AM
5.2 ZJ coasting RPM DROPS hesitation CStartzman ZJ Grand Cherokee Forum 1 02-28-2009 11:51 AM
Grinding noise - only when coasting ('05) Jeeps4life28 WK Grand Cherokee & XK Commander Forum 5 02-02-2009 06:03 PM
