Rpm drops when i hit a bump. - JeepForum.com
post #1 of 7 Old 10-03-2012, 10:07 AM Thread Starter
duhkooter
1994 ZJ
when im driving and hit a bump i used to get speed wobbles alone. as of lately the speed wobbles are now accompanied by my rpms dropping while my jeeps bouncing around, once the jeep is done bouncing around the rpms pick up from where they left off... what could the problem be here?
duhkooter is offline
post #2 of 7 Old 10-03-2012, 11:06 AM
speedin
loose wire?
speedin is offline
post #3 of 7 Old 10-03-2012, 11:46 AM
iser
sounds like something is loose. try smacking the pcm and see if rpm changes.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #4 of 7 Old 10-03-2012, 05:06 PM
JasonStebbins
Something sounds loose/getting a bad connection. Check all your sensors and battery terminals/grounds.
JasonStebbins is offline
post #5 of 7 Old 10-03-2012, 06:52 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
First, fix the death wobble.
Next fix your battery connections.
ratmonkey is offline
post #6 of 7 Old 10-03-2012, 06:59 PM
JasonStebbins
"Death wobble" as it is commonly known as here can be caused by many things. Start by checking both ends of the track bar. The bolt on the axle end can hallow out the hole allowing excess movement, and the ball joint end can fail just like any joint.
Have you checked your wheel bearings? Control arm bushings? Drag link? Upper and lower ball joints? Sway bar bushings/links? The steering stabilizer is not as significant but if it's toasted it will help some.
Report back.
post #7 of 7 Old 10-03-2012, 07:58 PM
PolkaPower
Possible fuel pump too.
PolkaPower is offline
death wobble , engine 5.2 , rpm
