Rpm drops then dies - JeepForum.com
post #1 of 5 Old 01-14-2013, 03:27 PM Thread Starter
duhkooter
1994 ZJ
Rpm drops then dies
when i start up my 5.2 it will idle perfectly fine if i leave it in park, if i drop it into drive it will idle for about 5 - 10 minutes before the rpms slowly drop to about 100 then it will die. if i try to start it immediately it wont crank over and the my battery gauge says my battery is nearly dead, but if i wait about 30 minutes or so shell fire right up again.
duhkooter is offline
post #2 of 5 Old 01-15-2013, 08:00 PM
ZeeJay1997
Sounds a lot like a bad battery or weak charging system.
ZeeJay1997 is offline
post #3 of 5 Old 01-15-2013, 09:46 PM
papitt
What kind of battery do you have. I had a gel battey that was bad and did that to me on a chevy years ago.
papitt is online now
post #4 of 5 Old 01-15-2013, 09:53 PM Thread Starter
duhkooter
1994 ZJ
I've tries jumping it multiple times after it died and it did work either time, so I'm not quite sure it's my batter or a charging system.
post #5 of 5 Old 01-15-2013, 10:43 PM
Bannerman53
check all your grounds, sounds like some sort of wiring/electrical problem
Bannerman53 is offline
5.2l , rpm , stalling
