Rough Turns - JeepForum.com
post #1 of 7 Old 06-20-2003, 03:34 PM Thread Starter
Sal
Rough Turns
I have a 94 GC with the Quadra-Trac and when I make tight turns the car really shakes and the steering wheel jerks. Is this normal with this full time 4*4? It reminds me of a old Chevy with locking hubs dog tailing. Any ideas?
Thanks
Salvatore
Sal is offline
post #2 of 7 Old 06-20-2003, 04:09 PM
spichman510
spichman510's Avatar
Its as normal as i've ever heard. everyone ahs this problem. Not exaclty sure Why: if its rubbing or the tires trying to pull the car at and odd angle. Prob the later. But its normal
Spicher
-'98 5.9 Grand Cherokee-
spichman510 is offline
post #3 of 7 Old 06-20-2003, 05:15 PM
Stocker
Definitely NOT normal!
Mine has never done it; from all I've read, that's a symptom of a failing (or failed!) viscous coupling (transfer case). Seems to be a pretty common problem. Try a search here or over at JU. Good luck!
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #4 of 7 Old 06-20-2003, 06:04 PM
spichman510
Stocker i got that checked out and no problems, and look and the post on replacing the the 249 with 242 one of the main reasons was the guy was angry about parking lots looking like a fool bucking in his jeep.
Spicher
post #5 of 7 Old 06-20-2003, 06:15 PM Thread Starter
Sal
Spichman510, You had it checked out by a shop. What did they say? Is this normal? Seems pretty weird parking, they jeep kicks like a mule, pretty funny to look at me park. Did these GC do this new?
Sal is offline
post #6 of 7 Old 06-20-2003, 06:33 PM
spichman510
This problem occurs at slow speeds right? This is not a sign of failing viscous coupling because the viscous coupling WILL do its job when the tire slips aka on a slippery road and very little traction. However, in a parking lot you will be going at such low speeds that the tire will have more than enough traction so that there will be no slipping aka the viscous coupling will still give equal power to each tire. So the bucking is caused by the truning front tires pulling the way they are pulling ang the back ones pusching forward causing a kinda push and pull thing but at high speed you do this and the front tires will lose traction causing a slip and the viscous coupling will do its job transfering power and less power to the front tires gives the backs more force and they will win this "tug o' war". At higher speeds stocker is right maybe even in the parking lot, there could be a problem but mine only happens at VERY low speeds, so i would get it checked out either way and see what they say.
Spicher
post #7 of 7 Old 06-20-2003, 10:07 PM
Ryan2son
Good information-thanks
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
4.7 ho hesitation with wot and right turns ChiliPepperTJ ZJ Grand Cherokee Forum 13 11-24-2009 11:21 AM
'03 WJ Blower Turns ON and OFF tonydotigr ZJ Grand Cherokee Forum 0 07-07-2009 06:31 PM
A/C turns on and off by itself trasard6 ZJ Grand Cherokee Forum 3 03-12-2009 07:11 PM
my zj turns like a crab wrestlerobx ZJ Grand Cherokee Forum 36 07-12-2008 04:21 PM
A/C Randomly Turns On Astorm WJ Grand Cherokee Forum 4 06-05-2004 06:21 PM
