Rough idle thermostat?? - JeepForum.com
post #1 of 3 Old 12-08-2011, 12:06 PM Thread Starter
jackedzj
1994 ZJ
i have been having serious idle problems for about 2 months now i legit replaced every part to the intake exhaust fuel system and ignition system and no luck not the car is overheating in 40 degree weather with a 160 thermostat if the thermostat stuck closed would it chock the water pump and cause a rough idle, hard warm starts, and occasional staling??
and if i may add and hope it helps the idle sounds like its cammed makes metal heads in traffic stare its really funny
~~~_______oooo_
~~ / ../...\...\_____\ The Big White Jeep
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
jackedzj is offline
post #2 of 3 Old 12-08-2011, 01:29 PM
LordHobbit
no. That's a weird idea.
Clean the throttle body especially the IAC with carb or throttle body cleaner. While you have the throttle body off, look into the intake for a pool of oil. If you ahve it, then your plenum gasket is bad.
After you do that, see if it idles better. If so, you could seafoam through the brake booster vacuum line and scare your neighbors.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 3 Old 12-08-2011, 01:32 PM Thread Starter
jackedzj
1994 ZJ
did all that already too took the intake apart cleaned everything replaced the intake manifold gasket and seafoamed it i love scaring the neighbors and nothing but why else would my truck be over heating
~~~_______oooo_
jackedzj is offline
02 Gc With Rough Idle, 4.0 Rough... evanlaczi ZJ Grand Cherokee Forum 4 05-09-2009 03:53 PM
Hi idle after thermostat opens? lma1973 ZJ Grand Cherokee Forum 3 03-15-2009 10:05 AM
rough idle? PLEASE HELP!!!! my96zjisjunk ZJ Grand Cherokee Forum 3 02-20-2008 06:40 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
Rough Idle with A/C on... CHEEP JEEP ZJ Grand Cherokee Forum 13 09-07-2006 11:22 PM
