Rough Idle/High Idle/Weird Shifting FIXED!! - JeepForum.com
post #1 of 6 Old 04-27-2007, 08:50 PM Thread Starter
UKFan4Sure!
OK, let me explain the original problem and I am hoping someone can benefit from my experience on my 99 WJ with the 4.0L......
About a month ago, my wife explained that the Jeep started "revving" high and wouldn't slow down. She thought it was going to get away from her and it scared her. It did finally die back down to idle though. I thought she was going nuts.....until it did it with me in the car with her one day about a week later.
About two weeks ago, it started running erratically and died several times like it wasn't getting fuel or spark. It also developed a habit of feeling like the tranny was slipping or bumping when going over a slight rise or float on the interstate. Kind of like it was catching up with itself.
Needless to say, I thought the tranny was going out, I had a manifold leak, and that the fuel pump was going out. Time to trade in the ol' Grand Cherokee......??
Not quite. I changed the plugs (had double the recommended gap ), and cleaned the IAC valve as recommended on this forum. It seemed OK at first, but last week, it did the same thing again. And again. Back to the drawing board. It also threw codes, PO123 (TPS Pedal Pos Sensor A Circuit High Input) and PO121 (A Circuit Range)
Enough is enough. I went to AutoZoned(out) and got both the TPS sensor and the IAC valve for a grand total of $101. I installed them both today and have had zero problems after 50 miles of driving. It is much smoother and doesn't have any problems now. It would hardly run yesterday.
Thought I would pass this on. I recommend changing them both as PM if you have over 100K on your car. Cheap insurance from a lot of headaches!!
UKFan4Sure! is offline
post #2 of 6 Old 04-27-2007, 11:12 PM
G4teamG
Darn it!!! Already did all of that and still have the same problem. Thanks for posting, though.
G4teamG is offline
post #3 of 6 Old 04-27-2007, 11:56 PM
litint
how hard to install the sensor and valve?
BLACK 98ZJ Limited 5.2
litint is offline
post #4 of 6 Old 04-28-2007, 01:54 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
easy on an I6 lots a room. it's a bit harder on the v8. definately need to pull the throttle body for it.
ratmonkey is offline
post #5 of 6 Old 04-28-2007, 07:43 AM
impuresoul2k3
Actually on my 5.2 I got both of mine out without having to remove the TB. The IAC is definitely a tight fit but it can be done.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #6 of 6 Old 04-28-2007, 07:43 AM
litint
just take off the throttle body? thats not hard i had to semi- do that when i used seafoam...yea obv i have the v8
litint is offline
4.7 Wacky Idle fixed with new Throttle Position Sensor riverview6067 WJ Grand Cherokee Forum 98 09-29-2015 02:11 PM
Bad Idle, Stalls, Running Like Crap? (FIXED IT) thecommander WK Grand Cherokee & XK Commander Forum 0 12-29-2009 08:10 PM
SHIFTING and idle PROBLEMS!!!!!!!! jeepsman101 ZJ Grand Cherokee Forum 6 01-06-2009 05:05 PM
high idle - not shifting after wheeling in snow gpJeep ZJ Grand Cherokee Forum 6 01-04-2008 12:24 PM
Idle Jumps High After Sitting at Idle gunthagunth ZJ Grand Cherokee Forum 0 09-21-2006 08:58 PM
