Rough Idle/check engine light on - JeepForum.com
post #1 of 6 Old 06-30-2009, 09:47 PM Thread Starter
Cherokee0512
2003 WJ
Hey Y'all,
My 03 grand cherokee has been running rough at idle, seems to shake the truck some. I also have a check engine light on. My local garage says I either have a bad O2 sensor or my catalytic converter is possibly clogged. How do I know which it may be?
Cherokee0512 is offline
post #2 of 6 Old 06-30-2009, 09:54 PM
xJoshxx
2012 WK
check the code
Retrieving codes:
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
http://www.wjjeeps.com/faultcodes.htm#SYSTEMS
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 6 Old 06-30-2009, 10:02 PM Thread Starter
Cherokee0512
2003 WJ
P0420
I am getting the same diagnostic code of p0420, could be an O2 sensor or the converter.
post #4 of 6 Old 07-01-2009, 07:14 AM
rm2001wj
rm2001wj's Avatar
That code is thrown when the downstream O2 sensor signal oscillates at nearly the same frequency as the upstream sensor signal. Normally the downstream sensor oscillates more slowly. It is very, very unusual for an O2 sensor to go bad in such a way to trigger the P0420 code. Because that just doesn't happen, the manufacturers use that method to gauge catalytic converter efficiency. You need to have the cat replaced.
With the right equipment, a mechanic can display the signal voltages from both the upstream and downstream at the same time and confirm that it is or not an O2 sensor problem. You might want to have that done before the cat is replaced, but there will be a cost for the diagnosis.
Bank 1 is the bank of cylinders on the driver's side in the V8. For the I6, it's the front three cylinders.
rm2001wj is offline
post #5 of 6 Old 07-01-2009, 04:36 PM
wj03grandy
2003 WJ
im having the same problem but my cel is not on. and im getting a very dark black soot building up on my tail pipe
wj03grandy is offline
post #6 of 6 Old 07-01-2009, 04:52 PM
volvite
try cleaning your idle air control vavle. you can buy cleaner at your local auto parts store, and the valve is on the right side of the TB when looking at the engine from the front.
volvite is offline
WJ Check engine light, rough running. Windowsrookie ZJ Grand Cherokee Forum 1 12-04-2009 11:21 PM
Check Engine Light On - Oxygen Sensor Cause bad Idle and Stalling/Hard starting Krayzie949 ZJ Grand Cherokee Forum 4 11-28-2009 09:02 AM
Eratic Idle & Check engine Light Zeal ZJ Grand Cherokee Forum 7 10-26-2009 08:49 AM
95 ZJ Runs rough/Check engine light txgpr ZJ Grand Cherokee Forum 5 08-28-2008 10:54 PM
check engine light and horrible idle XJ99RedNY ZJ Grand Cherokee Forum 11 11-25-2006 02:34 PM
