rough idle - JeepForum.com
post #1 of 5 Old 07-23-2003, 07:44 PM Thread Starter
demtjcj
rough idle
i have a93 grand cheokee with the 4.0 6cyl, it started a few months ago as a rough idle, which i thought it was just missing a cyl. so ichanged the plugs, wires,rotor, dist cap, fuel filter. still no luck. so i did fuel injector cleaner and cleaned the throttle body and still no luck. well it just seems to be getting worse. also if i start the car and dont let car idle for 20-30 seconds before i shift it will stall or come real close to it. and if i gas it to just about 1000rpms i cant tell that it is doing it. please help, i know it sounds confusing. thanks
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #2 of 5 Old 07-23-2003, 08:52 PM
spichman510
spichman510's Avatar
i got the exact same problem. I tried all those and coudlnt figure it out. i also want to know please help us!!!
Spicher
-'98 5.9 Grand Cherokee-
spichman510 is offline
post #3 of 5 Old 07-25-2003, 07:43 AM
automan25
It sounds like you might have a bad sensor then, or you Idle Air Control Valve might be faulty (quite common). Read the codes from your vehicle's computer to see if that steers you in the right direction. I'd explain how to do that here, but I don't know. I'm sure the technique has been posted on this forum before though, so just do a search to find out. I do know that it doesn't require any special tools, just your key, and a chart to decode the codes.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #4 of 5 Old 07-27-2003, 07:07 PM Thread Starter
demtjcj
does any one know how to check these problems on here. if you could describe the part. thanks
dan
demtjcj is offline
post #5 of 5 Old 07-29-2003, 11:02 PM
crazycuban226
same prob?
i got a 93' zj w/ the 4.0 also i just started driving recently my father was drivin it for a week or two and it was actin up so he assumed that i got a blown cyclinder but i changed the plugs and it got a lot better but its still stalling so i already bought an o2 sensor just have to install it see what happens im goin to do a compression test anyway just to check i'll keep everyone posted back @ this thread
everything i need to know to in life i learned from killing smart people and eating there brains....one by one the makos swim away w/ my sanity...
crazycuban226 is offline
242 Has a Rough Idle. Some_Anchovies ZJ Grand Cherokee Forum 30 10-04-2009 09:39 AM
02 Gc With Rough Idle, 4.0 Rough... evanlaczi ZJ Grand Cherokee Forum 4 05-09-2009 03:53 PM
rough idle fearthedeere69 ZJ Grand Cherokee Forum 8 08-13-2007 10:34 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
rough idle baroc ZJ Grand Cherokee Forum 0 03-18-2007 08:06 PM
