rough idel - JeepForum.com
post #1 of 4 Old 12-09-2011, 07:25 PM Thread Starter
bowtie_mike25
rough idel
ok maybe someone can help me out..... i have a 95 jgc with a 5.2 and last year when i first got it, it didnt run... long story short i put a used pcm in it and it ran awesome, i just started messing with it again and its been sittin a while, but the reason i parked it is cause it started running like ****. i drove to town one day and it started heatin up on me, come to find out the water pump went out so i put a new one in and ever since its got a rough idel when it warms up. i put new plugs, wires, cap, and rotor and even retimed it again from tdc. i have tryed everything i can think of, but i dont know 318 very well and dont know anything about pcm's and what go along with them but i learn fast and i am outta ideas.... can anyone help please.
bowtie_mike25 is offline
post #2 of 4 Old 12-09-2011, 08:13 PM
jnowak
Check the Idle air control valve, the throttle position sensor, and give the throttle body a good cleaning. Can use an old toothbrush along with throttle body cleaner(not carb cleaner) to clean the cylinder of the tb.
jnowak is offline
post #3 of 4 Old 12-09-2011, 09:11 PM
Candymancan
When you did the wires did you route them correctly ? If they are routed wrong meaning touching eachother and crisscrossed it can cause idle issue and lots of other stuff
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Candymancan is offline
post #4 of 4 Old 12-09-2011, 10:39 PM
JrMechanic
Re-timed as in you attempted to adjust the timing? There's your problem.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
hard starts, rough idel johnbizzle02 ZJ Grand Cherokee Forum 2 04-14-2011 10:49 AM
idel and weird shifting ???? bmx_hb_guy ZJ Grand Cherokee Forum 10 11-29-2009 11:55 AM
02 Gc With Rough Idle, 4.0 Rough... evanlaczi ZJ Grand Cherokee Forum 4 05-09-2009 04:53 PM
High idel and no power trowley ZJ Grand Cherokee Forum 0 05-06-2008 08:47 AM
'97 GC rough mnjeepmale ZJ Grand Cherokee Forum 4 06-28-2005 11:19 AM
