rough country lift ? - JeepForum.com
post #1 of 17 Old 01-28-2008, 06:34 PM Thread Starter
zjberry
if any one has or had a 4'' lift from rough country for there zj i was wondering if the kit comes with a t-case drop kit?
2000 Grand Cherokee LTD
zjberry is offline
post #2 of 17 Old 01-28-2008, 08:04 PM
Casper4x4
Casper4x4's Avatar
get IRO... ironrockoffroad.com better quality.
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline
post #3 of 17 Old 01-28-2008, 08:09 PM
KingPrat
shouldn't need a TC drop with 4" of lift.
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #4 of 17 Old 01-29-2008, 06:36 AM
sandman
yea, it doesnt come with one but you wont need one either.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 17 Old 01-29-2008, 06:52 AM
Katesdad
Katesdad's Avatar
IRO used to use rough country springs, might still. The bad things about RC lifts are relocation brackets and non adjustable control arms (if they still come with those). IRO adjustable control arms I am just not crazy about. I bought Rubicon express for the front of the jeep from Kolak. There are guys out there that have RC lifts and have no troubles. They probably dont come close to abusing their grand. IRO would be a step up and Kolak@aol.com would be a step up from there IMO.
Katesdad is offline
post #6 of 17 Old 01-29-2008, 07:34 AM
sandman
RCs arms are adjustable. but yea their t-bar drop brackets are crap.
1993 Jeep ZJ. 4.0
sandman is offline
post #7 of 17 Old 01-29-2008, 09:39 AM Thread Starter
zjberry
yeah im not using the brakets im getting a new adj. track bar. im putting 2" spacers in would i need to drop it then?thats why i asked
zjberry is offline
post #8 of 17 Old 01-29-2008, 10:16 AM
sandman
you may. i didnt. if you run that set up you will need longer brake lines, front and rear track bars, and since the RC kit only comes with 6 adj control arms you will need new front uppers. and if you wheel it you will need to find a way to keep the rear springs and BBs in place, thats what im dealing with now. im thinking limiting straps.
sounds like your going the same direction i did. the RC kit is the best bang for the buck out there even if you need to buy t-bars on top of it.
i will warn you though, i had horrible CS issues with RC.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 17 Old 01-29-2008, 11:49 AM
Derek33
Derek33's Avatar
on top of the kit, youre going to want upper front CA's, front and rear TB's, longer brake lines, longer rear sway bar links (bracket is cheap), and quick discos since you'll be increasing the height of hte lift.
also, at that height you may run into a problem with the stock steering hitting the bottom of your sway abr end links. i did and had to upgrade to knuckle to knuckle steering.
look into sway bars as well, or expect alot of body roll at that height.
Derek33 is offline
post #10 of 17 Old 01-29-2008, 12:47 PM Thread Starter
zjberry
it sounds like it would be better to not use the 2"spacers. where is the best place to get front upper CA's?
zjberry is offline
post #11 of 17 Old 01-29-2008, 12:52 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Whoa! you were planning on using the BB ontop of the 4 inch lift?
If so, you need all 8 control arms to be adjustable. If not, you are going to hate life.
At six inches of lift and non adjustable control arms, they will be very steep up front and you'll actually be pulling the front axle closer to the center of the jeep in effect shortening your wheel base.
You need the front 4 to be adjustable to be able to keep the axle where it should be.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 17 Old 01-29-2008, 12:55 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
For the rear, you'll need the adjustable control arms to be able to adjust for vibes.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #13 of 17 Old 01-29-2008, 01:33 PM Thread Starter
zjberry
after reading what everyone had to say i think im going to go with the 4.5" lift from ironrock with no spacers. it would get to price to get the Rough country and add all the extra parts. so thanks for all the help.
zjberry is offline
post #14 of 17 Old 02-01-2008, 01:13 PM
Marauder.45
Ouch,
$1200.
Are those control arms in that kit designed for that lift height? Or the same as stock length?
1998 ZJ 5.9L Stock............
For now ;)
Marauder.45 is offline
post #15 of 17 Old 02-01-2008, 01:28 PM
rmtomasin
i almost went with the rc lift but i decided to go with the iro and i'm really happy with that, i also needed to drop the tc with 4.5" of lift i had slight vibes. i'm on stock control arms, kinda wish i went with adjustables, or long arms, but the ride isn't to bad it would be alot better with adjustables, any higher though and i would be in trouble.
-Ryan-
Built Not Bought #233
98 ZJ I6
rmtomasin is offline
4in WJ Rough Country Lift JkTheItalianoWJ WJ Grand Cherokee Forum 31 12-07-2012 11:03 AM
zj rough country lift + BB soccerfreak3377 ZJ Grand Cherokee Forum 16 02-15-2011 08:02 AM
ZJ 4" Rough Country Lift Richard1997ZJ ZJ Grand Cherokee Forum 6 01-29-2010 05:40 PM
Rough Country 4" lift anyone have it? Ender42 ZJ Grand Cherokee Forum 4 06-30-2009 11:03 PM
Rough Country WJ 3.5" Lift Posers ZJ Grand Cherokee Forum 3 05-15-2009 11:08 AM
