Rough country bargain lift worth it? - JeepForum.com
post #1 of 5 Old 05-10-2013, 03:12 PM Thread Starter
SkiJ
1994 ZJ
I see that rough country has a 3.5 inch lift... the one where it reuses the rear springs in the front... my question is has anyone purchased this lift and had issues?
And my other question is if I have 2 inch spring spacers on now with the 3.5 suspension for a total of 5.5 inches would that be a bad idea? Or would I be better off with about a 4 inch suspension?
Thanks in advance!
SkiJ is offline
post #2 of 5 Old 05-10-2013, 03:26 PM
PolkaPower
You can't use a 2" puck with a lift designed for 3.5". 5.5" is a whole new ball park. You can use a puck if you have the rest of the lift parts for 5.5".
PolkaPower is offline
post #3 of 5 Old 05-10-2013, 04:39 PM
tucsonzj
if you wanna go 5.5, do it right, the puck idea will fail as it's missing tons of parts and adjustments. the 3.5 front<rear swap is common, lots of stuff on here about it. Many people order the kit and new rear springs (and some other stuff) just to have new all around
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #4 of 5 Old 05-10-2013, 05:05 PM
Dyn0mitemat
Rough country anything isn't worth it. You couldn't pay me to put their parts on my rig
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #5 of 5 Old 05-10-2013, 08:04 PM
kg6mov
Hears the voices
kg6mov's Avatar
Dyn0mitemat knows his ****.
5.5 is really getting into long arm territory. I really wouldn't go over 4 without long arms. Do it right the first time and you'll save money in the long run. Don't have money to do it right right now? Don't do it.
Even just running 3.5 you should do adjustable CA's to get things correct. And you probably will still rub 33's unless you cut. My 2.5" on 31's can follow tj's on 37's all day long. So stay there until you can go whole hog.
kg6mov is online now
