Rotors - front and rear - JeepForum.com
post #1 of 2 Old 08-07-2009, 10:57 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Are they the same on a 03 GC? Mrs K complained about groaning, so I just bought new front rotors and pads without checking first. Turns out it was the rear pads down to the rivets on the rotor. So I put the new front rotors on anyway and have a perfectly fine used pair left over now. The gouge in the rear rotor wasn't bad at all, so I just replaced the pads. But I'd probably put the used front rotors on if they'd fit.
Knoxes is offline
post #2 of 2 Old 08-07-2009, 11:15 AM
BlackShuck
I'm pretty sure you'll have to order the rears if you want to replace them. They are not the same as the front rotors.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline
Front Rotors UTChavok ZJ Grand Cherokee Forum 9 07-09-2008 10:13 AM
Replace all rotors or just front? WJHAWK ZJ Grand Cherokee Forum 12 06-08-2007 09:14 PM
96 front rotors jeeptorino68 ZJ Grand Cherokee Forum 8 06-27-2006 07:20 PM
Front rotors alan111 ZJ Grand Cherokee Forum 2 05-24-2006 08:14 PM
rear differential and front rotors Bigjake ZJ Grand Cherokee Forum 4 08-30-2002 02:44 PM
