Quantcast Rotor Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rotor Question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-28-2007, 12:44 PM   #1
parnell5150
Rotor Question
I have 97 5.2 ZJ w/ 79k miles on it and I have a couple of brake questions. I bought the vehicle used in 05 and all of the pads were replaced when I bought it. For the past year I have a problem with squeaking brakes when stopping as well as an almost oscillating squeak when I drive (it disappears when I apply brakes). The rotors are my number one suspect. Does this sound right to you guys? Can I just have them turned or should I just replace them? Will I have to replace the pads too, there's still plenty of meat on them?
You guys rock, thanks.
"Do or Do Not, There is No Try"
97 ZJ Laredo 5.2
R.I.P: 92 XJ 4.0
parnell5150 is offline   Reply With Quote
Old 03-28-2007, 02:26 PM   #2
V8 Grand
Brake dust can cause the squeaking. Does it go away for a while when you wash the Jeep? Do you feel any shaking in the steering wheel when you apply the brakes? Are your front wheel bearings in good shape?
V8 Grand is offline   Reply With Quote
Old 03-28-2007, 02:38 PM   #3
nashmd454
it sounds like rotors to me...but I will wait to hear your response to the previous post of washing it.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote
Old 03-28-2007, 02:39 PM   #4
98ZJ SFD
On the subject of rotors, if he replaces, what is the best suggestion for a replacement rotor brand? Pads too?
R.I.P. 98 ZJ Laredo SE 4.0, 42RE, 242, 2" Skyjacker BB, JKS Quicker Discos, Rancho steering stabilizer, Goodyear Wrangler MT/Rs, K&N FIPK, Kolak cat & back exhaust, 1200W 15" Cadence Beast subwoofer, Westin Safari bar, KC lights, Whelen siren, Whelen strobe lights, Whelen Slimlighter.
98ZJ SFD is offline   Reply With Quote
Old 03-28-2007, 02:54 PM   #5
nashmd454
alot on here will say brembo's...I can't argue...they are great. I have cross drilled and slotted on mine. I would also say as for pads to go with EBC Green Stuff...pricey...but great. But going with pads...make sure they are compatible with the rotors.
Old 03-28-2007, 02:58 PM   #6
nierace
2003 WJ
I've had good with just the standard replacement brakes from autozone
You man need to clean/grease the things that the pads slide back forth on...I don't know what they're called...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote
Old 03-28-2007, 03:18 PM   #7
Bloodbath
I am going to say brake dust. I had some cheap pads on mine and they squealed like a pig with a hot poker up its ( ! )
I threw on some ceramic pads and it went away instantly and hasn't come back.
Also, that anti-squeal you put on the back of the brake pads may help you out.
What nierace is talking about is the slide pin/bolts with the rubber boots your caliper slides on when they are compressed/decompressed. Make sure you clean and regrease them. If they are dry or there is dirt in there, they can bind and cause your brake pads to remain in contact with your rotor and cause it to overheat (which will cause squeal) and warp.
-Bill
1998 Red Grand Cherokee Laredo
6" Lift - 32 x 11.5 BFG MT's - K&N FIPK - MSD Ignition with Magnecore wires - JKS Control Arms, Trackbars and QD's - Addco Front Swaybar - Intake Swap - U-turn Steering Conversion
Bloodbath is offline   Reply With Quote
Old 03-28-2007, 03:32 PM   #8
parnell5150
The noise seems to be consistent whether it's clean or not. The only time it seemed to subside was after I spent a little time scoring the rotors last summer (they appeared glazed). The oscillating squeak never went away during that time though. I don't experience any shuddering or anything strange at the wheel, just an occasional groan when I have to really get on 'em. Could cheap pads exhibit this behavior? I have no idea on the condition of the bearings, I do wonder though. I haven't found a way to check them, any suggestions?
Thanks again.
97 ZJ Laredo 5.2
R.I.P: 92 XJ 4.0
Old 03-28-2007, 04:59 PM   #9
kirsch98gc6
4 brembo oem replacement rotors and set of satisfied pro pads from tirerack for $250 to my door, i love the setup and the pads make absolutely zero noise. Cant beat the setup for that price
Josh
98 ZJ 4.0 8inch LA, 36 inch Iroks, Ected Lockd-Alloy USA chromo'd HP30, Aussie Lockd-Crown chromo'd-trussed D35, other goodies
kirsch98gc6 is offline   Reply With Quote
Old 03-28-2007, 07:55 PM   #10
98ZJ SFD
What about this?
http://cgi.ebay.com/ebaymotors/Jeep-Grand-Cherokee-Frt-Rr-DRILL-SLOT-BRAKE-ROTORS-PADS_W0QQcmdZViewItemQQcategoryZ33564QQitemZ220095 802383QQtcZphoto
Old 03-28-2007, 08:42 PM   #11
Turbonut
Thanks again.
Next time you're slowing down with light pedal pressure and the brakes are making the noise, push harder on the pedal and see if the noise stops? Under light braking, and normal pad to rotor contact when driving, the pads move ever so slightly inside the caliper, creating the high pitch noise. If the noise stops under heavy braking, the pads will not move as the pressure of the caliper piston keeps them tightly pinned against the rotor.
If you find this test to be true, remove the pads and place some anti-squeal solution on the back of the pads before reinstallation and give it a try.
Turbonut is offline   Reply With Quote
Old 03-29-2007, 09:50 AM   #12
parnell5150
I'll give that a try. Thank you. On a related note, could cheap pads cause the rotors to continually glaze? If one replaces pads should you always have the rotors turned or vice versa (put on new pads with a rotor swap)?
97 ZJ Laredo 5.2
R.I.P: 92 XJ 4.0
Old 03-29-2007, 10:36 AM   #13
02_limited
I had a similiar issue awhile back and took the Jeep back to the dealership. They replaced a brake pad and greased everything. Then 2 weeks later, the squeak came back when braking or oscillating squeak at low speed driving. Dealer looked at it again and the rear right axle shaft was bent. Axle shaft was replaced and no more squeaks. How does an axle shaft get bent?!
I'll be replacing the rotors/pads soon.
02 WJ Limited 4.7 Quadradrive
02_limited is offline   Reply With Quote
Glock Forum
