Roof Leak - JeepForum.com
post #1 of 6 Old 02-18-2003, 07:35 PM Thread Starter
Hammerhead
Roof Leak
Anyone else have a problem with water in the floorboards after a storm? (94 GC)
Hammerhead is offline
post #2 of 6 Old 02-18-2003, 07:39 PM
Swamp Boy
Swamp Boy's Avatar
Wow I was just thinking my roof must be self sealing I drilled
a hole in it under the roof rack to run wire for my KC's and I didn't bother sealing it at all. (Dumb I know but It has been raining and
I didn't want to get wet.) But it hasn't leaked a drop .. Craziest thing.. As far as your leak I would feel the roof if it feels damp or the doors aren't closing good you can adjust the striker ..
Give more info on where the water is and how you think it may be getting in..
If you don't know take it to a car was ..The drive thru kind and sit in it and look for the leak..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 6 Old 02-19-2003, 08:03 AM Thread Starter
Hammerhead
Not a bad idea!
post #4 of 6 Old 02-19-2003, 09:06 AM
Beachead19
Beachead19's Avatar
If you are getting water in the driver/passenger footwells then it could be your ac compressor letting moisture into the cab. This is a common problem for 93-95 ZJs. I'll look for some sites and post back later.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #5 of 6 Old 02-20-2003, 09:02 AM Thread Starter
Hammerhead
Thanks! It does it when it rains too.
post #6 of 6 Old 02-20-2003, 09:14 AM
Beachead19
Beachead19's Avatar
Read This
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Interior Roof Leak sunflash2012 ZJ Grand Cherokee Forum 28 10-06-2013 08:10 PM
WJ roof leak rugermack ZJ Grand Cherokee Forum 10 05-22-2009 06:08 PM
06 roof a-piller water leak zjdxj WK Grand Cherokee & XK Commander Forum 5 12-13-2008 12:12 AM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 05:58 PM
anyone ever get a water leak through the roof......... TheOle34 ZJ Grand Cherokee Forum 2 10-12-2005 11:55 AM
