Roller rockers in a 318? - JeepForum.com
post #1 of 4 Old 11-20-2003, 01:56 PM Thread Starter
JumpinJack
Have any of you put roller rockers in the 318?
Just wondering what kind of benifits I'd gain.
Thanks,
jack
JumpinJack is offline
post #2 of 4 Old 11-20-2003, 03:39 PM
iroc22
iroc22's Avatar
You will gain a maybe 3-5hp in swapping all 16 rocker arms to roller rockers keeping the same ratio. I haven't even seen any rockers for the magnum pedestal stud mounted arms cylinder heads. Where have you seen the roller rock arms?
iroc22 is offline
post #3 of 4 Old 11-20-2003, 03:47 PM Thread Starter
JumpinJack
I saw them on ebay, crane make a set as well, but you have to change everything from the lifters up including the valve covers.
My valve covers are starting to leak and since I was going to remove them to get the gasket changed, I was thinking about putting some 1.6 rollers in. If it was worth it....
post #4 of 4 Old 11-20-2003, 11:28 PM
iroc22
iroc22's Avatar
If you're swapping in the 1.6's then you should see a bigger increase than just 3-5hp, maybe in the neighbourhood of 15hp. It's all guesses unless you dyno it.
iroc22 is offline
Roller Rocker Problem Tazenutz ZJ Grand Cherokee Forum 5 07-20-2009 09:55 AM
Roller Rockers on a 5.9 ngc1068 ZJ Grand Cherokee Forum 9 06-24-2009 05:38 AM
4.0 roller rockers Minivan ZJ Grand Cherokee Forum 3 04-03-2009 07:49 PM
Crower ss rockers 1.7 nashmd454 ZJ Grand Cherokee Forum 8 02-05-2008 10:22 AM
rockers scubatch2 ZJ Grand Cherokee Forum 4 01-01-2006 07:35 PM
