Roigh country 4 inch x flex - JeepForum.com
post #1 of 6 Old 02-29-2012, 07:57 PM Thread Starter
Flat_Black_ZJ
Ok so i finally got my lift i got the rough country 4 inch x flex and im getting ready to put it on and i was wanting some input on how tight the spanner nut should be put on with they are first assembled. rough country says to just tighten the nut intll it is snug against bushing and then go about a 1/4 turn more but that seem loose.
Flat_Black_ZJ is offline
post #2 of 6 Old 02-29-2012, 08:07 PM
mcgr21
As tight as you can get it and then it will still loosen up and need to be tightened down the road. Problem is not breaking those little bolts on the wrench. I went through a bunch. There is a video on YouTube of domineering putting his together.
O ||||| O
mcgr21 is offline
post #3 of 6 Old 02-29-2012, 08:08 PM
mcgr21
I meant someone...got autocorrected
O ||||| O
mcgr21 is offline
post #4 of 6 Old 02-29-2012, 09:42 PM
JohnnyZJ
i went as tight as i could. thres little threaded bolts to put in the arms to keep the sides in place...... did you not get them/install them?
it wouldn't surprise me.
when i ordered the winch plate it didn't come with fracken hardware........
07' JKUR rollin on 35s
JohnnyZJ is offline
post #5 of 6 Old 02-29-2012, 09:52 PM
mcgr21
No I did, I don't know how but they do. Must wear a little. You'll know cause they'll start to clunk.
O ||||| O
mcgr21 is offline
post #6 of 6 Old 10-06-2013, 10:57 AM Thread Starter
Flat_Black_ZJ
I tightened mine down to what rough country said we'll see how they hold up. Im finally getting my lift on.
4 inch rough country x flex kit 98gczj ZJ Grand Cherokee Forum 34 08-17-2011 12:39 PM
93 jeep ZJ with 4 inch flex arm RC lift snitch23 ZJ Grand Cherokee Forum 4 03-06-2011 05:42 PM
4" Rough country X-flex question mudruna ZJ Grand Cherokee Forum 6 02-22-2011 10:11 PM
rough country 4in x-flex cklanish88mj ZJ Grand Cherokee Forum 1 02-21-2010 03:03 PM
What size tire for max flex 3.5-4 inch lift trailblazr81 ZJ Grand Cherokee Forum 5 03-02-2009 09:56 PM
