Quantcast rocky road - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > rocky road
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 06-13-2008, 12:06 AM   #1
crazydude2500
rocky road
ok i bought a rocky road lift kit 4.5 inch and im 1/2 way throught it moving to the back they use a drop bracket is this good or bad ? was i stupid for buying this kit, im new to this form and it seems they have crapy service but are their kits crap can i expect drive line vib's from this kit? also should i install the 1 inch t-case drop kit ? im hoping to drive this come saturday.....this is my first lift kit so im a little lost and their is no one around here to help...ill be the highest zj around
crazydude2500 is offline   Reply With Quote
Old 06-13-2008, 12:25 AM   #2
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Okay, after reading your PM.
The Tcase spacer is designed to mitigate the vibes. Try it. You won't go wrong by using it.
Remember to retighten all the bolts after a break in period of driving around. You may find that you forgot to tighten one.
Hunter
BTW, I'm moving this to the ZJ tech section.
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 06-13-2008, 06:45 AM   #3
nierace
2003 WJ
The drop bracket isnt the greatest, but you should be fine with it out back, most of the time the only reason have problems with the drop brackets is due to them dropping down the trackbar and not the draglink or vice versa which creates bump steer. Since theres no drag link in back your good to go.
I would try running it without the tcase drop before putting it in, you dont need to have everything apart to do it so to take it for a test run - find you have vibes - then take it back and put it in isnt a big deal.
If you go to Tremont, PA you'll find that you're not the highest ZJ around
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote
Old 06-13-2008, 10:00 AM   #4
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
who is??????
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/
5.9 ANDY is offline   Reply With Quote
Old 06-13-2008, 10:12 AM   #5
nierace
2003 WJ
Originally Posted by 5.9 ANDY View Post
who is??????
Theres a few guys in that area - Rausch Creek is right there so....
I've seen a couple over 6.5"
Nickerdoodle
35" BFGoodrich KM2
kolak@aol.com
Old 06-13-2008, 10:23 AM   #6
crazydude2500
aw man did ya have to pop my bubble before it was even done haha thanks for the advice any tips on how to do the back end or any tips at all would help...did u install ur kit... and your from tremont sweet..wat about u any where are you from
Old 06-13-2008, 10:27 AM   #7
nierace
2003 WJ
I'm from CT - I just wheel down there
Use PB blaster on any bolts/nuts will make your life a bit easier.
Nickerdoodle
35" BFGoodrich KM2
kolak@aol.com
Old 06-13-2008, 10:38 AM   #8
crazydude2500
ooooo how often do you come down to wheel ?? im a little worried about the rear track bar bolt i tryed breaking it loose with a 3ft breaker bar and didnt work so im going to try my impacts on it hopefully it wll break loose its kinda tight with the bumpstop there i might have to try to take it out as well
Glock Forum
