Roaring front end - JeepForum.com
post #1 of 4 Old 08-14-2009, 08:40 AM Thread Starter
vworley
Roaring front end
Well, I've got a roaring sound coming out of the front end. I've just finished replacing both CV joints, bearing hubs, rotors and pads. Still have the roar. It seems to clearly be "timed" with the wheel rotation, but I'm fairly sure it's not the tires. Any ideas? Could the gear box be low on oil or something similar.
Not a mechanic, but learning...
vworley is offline
post #2 of 4 Old 08-14-2009, 09:34 AM
99avant
Does the noise change or go away when you are on or off the throttle? You may have a differential issue.
Check the fluid for correct level and make sure there is nothing foreign in there (water, metal flakes)
There are a few bearings in there that go bad with time and poor fluid maintenance.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #3 of 4 Old 08-14-2009, 09:37 AM Thread Starter
vworley
It does seem to change with throttle. How can I check the fluid level?
vworley is offline
post #4 of 4 Old 08-14-2009, 09:43 AM
99avant
There is a plug on the front cover, take it off. The fluid should be about to the level of the bottom of that hole.
If I were you I would drain it, inspect the fluid and fill it back up. Should be a pretty simple operation for you since you have done that other work. There are multiple write up threads around here if you want specifics on the process.
Another possibility is your front drive shaft. What are the specifics on your jeep? (fill out your profile so we can help you easier)
If your driveshaft looks like this:
That may be the issue. The rubber boots at the ends crack and the grease leaks out.
The driveshaft and a bearing in my front diff were causing a noise similar to what you are hearing.
99avant is offline
Roaring / Grinding sound coming from front ajnolin ZJ Grand Cherokee Forum 3 01-10-2010 11:08 AM
Could this cause roaring? PICS manofmany ZJ Grand Cherokee Forum 29 01-22-2009 07:15 PM
RE: Roaring Noise uncc09meet ZJ Grand Cherokee Forum 2 08-13-2007 03:08 PM
How much roaring is normal? uncc09meet ZJ Grand Cherokee Forum 17 08-03-2007 03:59 PM
Roaring!!!! man this is annoying... Reloader77724 ZJ Grand Cherokee Forum 23 08-01-2006 11:01 PM
