Road worthy steering setup w/ 5-6" lift - JeepForum.com
post #1 of 11 Old 08-05-2009, 11:08 PM Thread Starter
Toliver09
1991 XJ Cherokee
I am sitting at 3.5" lift on my 97 ZJ, this is my daily driver but I DEFINATELY wheel it when I get the chance. I will be installing a 5.5-6" long arm kit before too long and I will need to eliminate the inverted y-link setup thats on it, it just doesnt seem safe at all. My only problem is I cant seem to find an otk kit that doesnt use heim joints. I'd love to find a setup that still uses tre's. anyone have ideas on if I could custom make something or swap knuckles or what would be the safest most effective way to make steering at 6" of lift safe?
98% of drivers say "oh crap" when they see snow, the other 2% are Central Illinoisans that say "Hold my beer and watch this!"
Toliver09 is offline
post #2 of 11 Old 08-05-2009, 11:13 PM
sandman
Jcr............
http://www.jcroffroad.com/Merchant2/...tegory_Code=S6
the inverted y set up is good up to 6". you can even make it highsteer.
http://motionoffroad.com/catalog/ind...roducts_id=306
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 11 Old 08-05-2009, 11:22 PM Thread Starter
Toliver09
1991 XJ Cherokee
I like the idea of the 1ton setup, having the Y link just scares me because of the higher angles of the drag link. I think if I ran any more lift when I droop the passenger side it will stress the TRE at the pitman arm. am I worrying over nothing or is this a good concern?
post #4 of 11 Old 08-05-2009, 11:33 PM
sandman
no, thats a true concern. if you plan to have a bunch of flex and dont want heims the OTK JCR steering is your set up. you will also need to swap to a double shear track bar. if you run a set up with a lower bracket like IROs conversion you can also run a DPA which will help with steering angles.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 11 Old 08-05-2009, 11:34 PM
Boodyrider
Or get the same tie rod flip insert for 18 bucks instead of 30:
http://www.goferitoffroad.com/products.htm
Originally Posted by sandman View Post
Jcr............
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #6 of 11 Old 08-05-2009, 11:34 PM Thread Starter
Toliver09
1991 XJ Cherokee
thank you kindly sir
post #7 of 11 Old 08-06-2009, 05:01 PM
LSRGreg
i had a hi-steer set up from down east offroad on my ZJ. It used WJ knuckles, and they were connected to a tie rod. The tie rod had a hole in it on the driver side, that the drag link connected to, so it didn't have the toe changes and issues that the y link set up has. Just like the JCR set up above. But since it used WJ knuckles, i had to raise the track bar mount on the axle as well, since the new location of the drag link was much higher than the old location with the stock ZJ spindles. It drove great at 5" of lift.
G-
04 WJ, Limited, 4.7 HO, w/ lots of goodies
Incline Winch bumper from WWW.FRANTZDESIGNWORKS.COM
LSRGreg is offline
post #8 of 11 Old 08-07-2009, 11:12 AM Thread Starter
Toliver09
1991 XJ Cherokee
G-
I did think about a WJ knuckle swap but didnt know much about it. Thanks for providing another option!
post #9 of 11 Old 08-07-2009, 01:35 PM
LSRGreg
I don't think down east offroad is around anymore.. so probably not much help. I know there was some special spacers that had to be used, along with chevy S-10 brake calipers etc... so it wasn't cheap.
Here is the set up i did on my WJ i have right now..
track bar mount from TNT customs, flipped the drag link on top of knuckle mount with 1 ton chevy ends that have tons of angle for major droop, and left the factory tie rod (just replaced shaft with Kevin's HD). I will be flipping the tie rod as well.
LSRGreg is offline
post #10 of 11 Old 08-07-2009, 05:36 PM
sandman
the problem is that WJs have a different bolt pattern so you need to weld on spacers and drill out the rotors. trucks did it to their 5 grand cherokee project.
teraflex has a highsteer that replaces the knuckle, you can buy just the knuckle too
http://www.teraflex.biz/products/high-steer-system.html
KOR also has a good kit.
http://www.kevinsoffroad.com/steeringupgrades.html
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 11 Old 08-07-2009, 10:39 PM
sandman
http://www.pirate4x4.com/forum/showthread.php?t=809662
^^ read this thread. ^^
just tossing another idea out there for you
1993 Jeep ZJ. 4.0
sandman is offline
The Rocky Road 2.25" lift... K2-DAN WK Grand Cherokee & XK Commander Forum 17 11-11-2015 02:36 PM
ROCKY ROAD 2.25 "LIFT" iNSTALLED!!! coyote runner WK Grand Cherokee & XK Commander Forum 18 11-11-2009 08:10 PM
2006 Grand Cherokee is it off road worthy ModernJ WK Grand Cherokee & XK Commander Forum 6 07-29-2009 10:02 AM
Big Lift Steering Setup Darthteddy ZJ Grand Cherokee Forum 17 09-15-2008 07:42 PM
2.5" Rocky Road Lift mrfWKJeep WK Grand Cherokee & XK Commander Forum 6 08-11-2007 07:29 AM
