Rims that wont make your tires rub! - JeepForum.com
post #1 of 8 Old 08-14-2013, 04:02 PM Thread Starter
tmacw122
Hey jeep forum! I just got some general grabber at2 235/75-15 for my grand cherokee and I threw them on some rims that I found on Craigslist for cheap but the have very little back spacing so I had to put the tires on the stock rims for now..
I was looking online and I really like these http://www.jeep4x4center.com/black-r...952571245.html
These have a 4 1/2 in back spacing and are 15x7 so I'm pretty sure they will tuck into the wheel well or be at least very close to the stock rims back spacing, I just want to
make sure. Stock offset is 2.85 in and these are 2.5 so they should be close.
Any input is great!
Jnddndndjd
tmacw122 is offline
post #2 of 8 Old 08-14-2013, 04:14 PM
WhiteOut
WhiteOut's Avatar
You'll be fine with those, they will stick out a little bit further since stock backspacing is more than that.
WhiteOut is offline
post #3 of 8 Old 08-14-2013, 05:37 PM Thread Starter
tmacw122
I'm just worried they will rub the wheel well like they did before, even if it is just a tiny bit I'd like to avoid rubbing as much as possible. I'll post pictures later to exactly where it is rubbing
tmacw122 is offline
post #4 of 8 Old 08-14-2013, 05:48 PM
dbmorris99
im running 31's on canyon wheels with stock suspension and the only time i rub is if i cut the wheel to hard
dbmorris99 is offline
post #5 of 8 Old 08-14-2013, 06:24 PM Thread Starter
tmacw122
Here are my stock rims with new tires and that is where the other rims were making them rum and I hope that the new rims don't touch that trim at all like the stock rims do
tmacw122 is offline
post #6 of 8 Old 08-14-2013, 08:04 PM
dnuccio
Your springs might be sagging if you're rubbing with that size tire on those rims. I ran 30x9.5r15 on those rims on stock suspension and it only rubbed if I turned full lock
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 8 Old 08-14-2013, 10:40 PM
jeep-pr
i bought mine with 31x10.5x15 on the stock rims, but i have the up country suspension and i only get rub on full lock.
When the presence of a check engine light is comforting, because you know "everything is as it should be."
jeep-pr is offline
post #8 of 8 Old 08-15-2013, 09:59 AM
PolkaPower
Yea that's hitting the fender. Usually they only rub the control arms at full turn with wider tires. Saggy coils and shocks maybe? Do you still have a bump stop back there?
PolkaPower is offline
