rim and tires size Q - JeepForum.com
post #1 of 11 Old 11-15-2007, 08:37 AM Thread Starter
95ZJ
got a new set of tires a bit ago and thier 11.5 wide. should these fit out on a 7" rim or would be it a better idea to go grab a set of 8" wide wheels.
right now i got 10.5 on the 7" rim and it looks fine so i was thinkin it should be ok, just wanted some input though
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline
post #2 of 11 Old 11-15-2007, 09:02 AM
04WJfreedom
04WJfreedom's Avatar
I think they will work but i wouldnt air down to much to go wheeling, 8" rim would be better IMO.
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #3 of 11 Old 11-15-2007, 09:21 AM
chipmunkchyc04
i have 32*11.5 on 15*7 rims... i keep the air around 25 in them and they are fine, i dont air down off road though....
*Female*Jeeper*
chipmunkchyc04 is offline
post #4 of 11 Old 11-15-2007, 10:53 AM
tennesseewj
yeah you should be okay unless you like to air down
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #5 of 11 Old 11-15-2007, 01:52 PM Thread Starter
95ZJ
ok thats wat i figured, just wanted to get some feed back though.
chipmunkchyc04-i like the rims on there, i was thinkin of running the same ones but get them done in black. wats the back spacing on those BTW? my tires are 10.5 right now and they were rubbing a bit already
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline
post #6 of 11 Old 11-15-2007, 02:15 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
11.50 wide tires on 7" wide wheels is perfect.
Not true.
You're less likely to unseat a tire with a 7" wide wheel vs. an 8" wide wheel.
The narrower wheel holds onto the tire bead better. Its harder to push the tire bead inwards and unseat it with the narrower wheel. If you've ever mounted or dismounted tires, you know exactly what I'm talking about.
Wheelin98TJ is offline
post #7 of 11 Old 11-15-2007, 02:23 PM
tennesseewj
I see what you're saying, but it seems like on a very narrow rim the bead would tend to push itself out rather than in. I'm not arguing with you, just kind of thinking out loud.
I always just play it safe and get a width that I know for a fact will work with my tire
2004 4.0 Selec-Trac
post #8 of 11 Old 11-15-2007, 02:50 PM Thread Starter
95ZJ
would a 3" back spacing rim be ok to run? ir should i got 3.5-4"
thier 31x11.5x15 with a 2"BB
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline
post #9 of 11 Old 11-16-2007, 01:18 AM Thread Starter
95ZJ
anyone?
3" ok or no
wat about 35mm? is that normal for jeep wheels?
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline
post #10 of 11 Old 11-16-2007, 11:18 AM
chipmunkchyc04
well, the rims i have are stock 89 cherokee rims... picked them up with tires for $75 BUT i have 1.5" wheel spacers and im good.... without them i rubbed on the ca's pretty bad... now i just hit fenders... you'll need trimming
*Female*Jeeper*
post #11 of 11 Old 11-16-2007, 02:03 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
3.75 to 4 inches of backspacing is optimal on ZJs.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
What size tires can i fit? shdybrady19 ZJ Grand Cherokee Forum 4 04-06-2009 07:22 PM
what size tires? asessa ZJ Grand Cherokee Forum 1 07-01-2008 09:35 AM
What size tires?? redrubi04 ZJ Grand Cherokee Forum 4 09-10-2006 08:00 PM
What size tires? Swiggs ZJ Grand Cherokee Forum 5 07-18-2005 09:50 AM
what size tires do i need to ask for? nineseventhree ZJ Grand Cherokee Forum 2 06-01-2003 09:38 PM
