right side braking drum making noise after brake job - JeepForum.com
post #1 of 2 Old 03-28-2013, 11:30 PM Thread Starter
tylersjeep
1994 ZJ
my right rear brake drum is making a grinding sound after brakes and hardware install, last time I did a brake job I did not hook up the parking brake e-brake up I took the tire off after it did the noise everything seems fine I dont get what the noise is? the reason for me doing the brake jobs is the same tire was make noise before so I did a brake job now its making a grinding noise after the job what gives.
tylersjeep is offline
post #2 of 2 Old 03-29-2013, 09:28 AM
LordHobbit
did you replace the drum? Are they adjusted poorly?
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
