Right Rear Noise - JeepForum.com
post #1 of 10 Old 04-16-2012, 11:41 AM Thread Starter
Dluenz
Right Rear Noise
I was beating the crap out of my 1993 zj and I hit the gas hard around a turn and I heard a POP. Now when I am turning or accelerating I hear the same pop. It almost sounds like its under the seat in the back (but its under my jeep). Any ideas?! Thanks!!!!
Dluenz is offline
post #2 of 10 Old 04-16-2012, 12:20 PM
JasonStebbins
If you hear it under the back seat, I would start by checking the rear drive shaft u-joints and transmission mount. Then rear upper control arms. Then rear sway bar links. Then rear sway bar bushings. In that order.
Poop
JasonStebbins is offline
post #3 of 10 Old 04-18-2012, 06:48 AM Thread Starter
Dluenz
It randomly went away, so that's good I guess?
1998 ZJ Limited 5.9
Dluenz is offline
post #4 of 10 Old 04-18-2012, 09:21 AM
gabrod72
Yes and no. It will probably come back soon enough. You need to trouble-shoot to find out what's wrong. The sound you are hearing will probably come back if you put stress on your rear suspension components (if that's what is causing it.) You can start trying to isolate your issue by finding some sloped surface and creeping onto it and off of it with the rear end. Drive slowly to see if you can hear the pop. If you can, then get a friend out there to look underneath the vehicle while you do this... obviously, don't let your friend actually get under the vehicle to inspect unless you know exactly what you are doing. I've been under one or two vehicles inspecting to help out my friends but I really, really trust their ability to avoid running over my arse!
gabrod72 is offline
post #5 of 10 Old 04-18-2012, 11:04 AM Thread Starter
Dluenz
Yeah I just beat on it a bit and it's completely gone. I just had new bushings out on by control arms, maybe they were getting situated?
1998 ZJ Limited 5.9
Dluenz is offline
post #6 of 10 Old 04-18-2012, 11:18 AM
gabrod72
Did you grease them? They'll squeal a bit if you don't but I'm not sure about popping. Try seeing if you can re-produce the popping sound, then loosen them and get some grease in there. Finally, tighten them with the vehicle sitting on it's own weight and try to reproduce the popping sound.
gabrod72 is offline
post #7 of 10 Old 04-18-2012, 11:25 AM Thread Starter
Dluenz
alright. Thanks for the help!
Dluenz is offline
post #8 of 10 Old 04-20-2012, 11:28 AM Thread Starter
Dluenz
yeah its back, yay somethines wrong haha
Dluenz is offline
post #9 of 10 Old 04-20-2012, 11:35 AM
gabrod72
Get someone to look underneath while you're power breaking... basically find a way to reproduce the sound under stress while not rolling if possible. Get a friend to look at it from the side while he's laying down and perhaps you can pinpoint your problem. If it started happening after your BB, then inspect your axles and linkages for any paint scrapes since this could be the evidence you are looking for.
gabrod72 is offline
post #10 of 10 Old 04-23-2012, 11:46 AM Thread Starter
Dluenz
I dont have my BB on yet, I was hoping to do that soon but now im worried about this, it seems like it happens when the vehicle is wet?
Dluenz is offline
jeep , pop , zj
5.9 rear end noise johnldayii ZJ Grand Cherokee Forum 1 03-11-2012 11:21 PM
97 zj rear end noise D3V0311 ZJ Grand Cherokee Forum 1 02-20-2011 07:19 AM
Rear End Noise Flyinbrick ZJ Grand Cherokee Forum 1 11-30-2010 08:29 AM
noise in the rear. ghost7122 ZJ Grand Cherokee Forum 1 02-23-2010 05:57 PM
rear end noise bryans 86 ZJ Grand Cherokee Forum 0 04-09-2006 07:12 PM
