Right Rear door won't catch...Wont stay closed!!! - JeepForum.com
post #1 of 9 Old 12-03-2006, 08:49 PM Thread Starter
Starrman
Just happened tonight.....ran by the house to pick up some clothes (powers been out since Thursday nights ice storm) and when putting some stuff in the back seat the door just bounces back open when trying to close it. I checked out the latch mechanism on the edge of the door and it looks like it operates correctly but it doesnt stay "in" when pushed. I'm hoping that something's just frozen inside the mechanism and not broke.
Anyone have a similar problem, and what was it?
'93 Jeep Grand Cherokee Laredo 5.2l
Starrman is offline
post #2 of 9 Old 12-04-2006, 05:10 AM
hinchcliffe
hinchcliffe's Avatar
Had the same issue in my BMW when it gets below 20, I sprayed some White Lithium Grease all over the latch mechanism, seemed to cure it.
'06 XK Inferno Red Crystal Pearl/Gray Leather
hinchcliffe is offline
post #3 of 9 Old 12-04-2006, 05:39 AM
gunthagunth
gunthagunth's Avatar
what you want to do is start it up with the heat on high. Let it sit with the door closed for like 15-20 mins. when you come back out it should latch. then spray everything down with lithium grease or penetrating oil. while your at it spray down the rubber door seal that goes around your door. I drove to work one day when my door wouldnt latch. it was funny holding the damn thing shut trying to keep the interior light from flickering.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #4 of 9 Old 12-04-2006, 09:22 AM
S_L_W
I had the same problem(same door even) the other day when it got cold, i'll have to try the suggestions you guys gave.
S_L_W is offline
post #5 of 9 Old 12-04-2006, 09:59 AM
gunthagunth
well spray the door gasket with pam or wd40 not lithium grease.
post #6 of 9 Old 12-04-2006, 05:25 PM Thread Starter
Starrman
After sitting in the sun today it works fine. Something must've been frozen stuck but I had just driven about 30mins and it was nice and warm inside, so I figured that wasn't the case and something was broke.
The funny thing is, it's been working fine since the ice storm Thursday and just did this Sunday night. I think what happened was that it sat out in the sun all day and a lot of the ice on the roof melted and ran down then re-froze after it got dark
Starrman is offline
post #7 of 9 Old 12-04-2006, 06:20 PM
TheAngus
TheAngus's Avatar
my right rear door on my 93 started doing that recently, i just smash it shut, always worked for me
1998 ZJ Limited 5.9L l Vortech Supercharged l SCT, 42lb Bosch, 255lph l Kolak 3" Exhaust w/ E-Cutout l KOR TB Conversion l Addco Swaybars F/R l JKS Rear TB l ORO U-Turn Steering w/ OME stabilizer l RE 4.5" Springs and Monotube Shocks l IRO Rear CAs l Kolak Ignition l Clayton Fronts l
TheAngus is offline
post #8 of 9 Old 12-04-2006, 06:41 PM
01ACRViper
if you take the latch mechanism out, you can see if the springs inside have fallen out of the track. some careful realigning and holding things together while screwing it all together is all the skill it takes to fix that little annoyance.
01ACRViper is offline
post #9 of 9 Old 12-04-2006, 07:10 PM
driabyor
driabyor's Avatar
1994 ZJ
mine does the same thing.... the fix... it's easy
First dont lock the door. Next push the door shut, then push the outside button.
It should have latched then.
mine only does it when it get cold.
some times when i lock the doors first it wont latch . unlocking the door will sometimes work by itself. But usually I have to hold the door shut ,then push the outside button that opens the door.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
Rear Door Wont Open!!!!! r34civic ZJ Grand Cherokee Forum 5 01-08-2010 06:22 AM
ZJ Driver's rear door wont open, Locked shut! SupaJosh ZJ Grand Cherokee Forum 0 02-12-2009 08:01 AM
Busted door lock Catch 22 - need help dontall ZJ Grand Cherokee Forum 0 02-10-2009 06:52 AM
Rear Door Lock Stuck-Door wont unlock automatically jeepergirl19 ZJ Grand Cherokee Forum 1 12-04-2007 08:52 AM
Rear Door Locked, wont open, manual lock broke jallman ZJ Grand Cherokee Forum 6 12-26-2005 07:50 PM
