Is this the right position on the Battery Gauge - Page 3 - JeepForum.com
post #31 of 34 Old 07-11-2009, 04:31 PM
wickerham
Me and my brother both own '93 ZJ's and both of ours also read the same spot.
Mine is new to me (owed less than a week) he's had his awhile and says it always read there.
wickerham is offline
post #32 of 34 Old 07-11-2009, 04:38 PM
ZeJokee
Mine reads 14 volts when nothing but the radio is on. If I start to turn other stuff on it drops to about 9 V when idling.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #33 of 34 Old 07-11-2009, 08:03 PM
comptiger5000
ZeJokee - That's a sign of either alternator not keeping up, or very likely on a 93, dirty wiring connections. Casper - The battery itself if probably fine, just not fully charged. I'd say charge the battery up, drive it for a while, and see if it gradually drops off.
comptiger5000 is offline
post #34 of 34 Old 07-12-2009, 09:27 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
93 is also notorious for the regulator in the pcm to go out. that would cause an issue like that as well. needs to test alt and battery.
if you're not getting between 13 and 15 volts at all times while running, something in your system is NOT keeping up or working correctly.
ratmonkey is offline
Battery gauge drops after installing new serp. belt rookie79 ZJ Grand Cherokee Forum 13 01-22-2010 08:06 PM
Battery gauge and rpm's drop at idle, causing overheating im90gsx ZJ Grand Cherokee Forum 5 07-05-2009 03:28 PM
Gauge of battery cable RichP WK Grand Cherokee & XK Commander Forum 2 03-18-2009 03:54 PM
Tried new Battery ? gauge still falls ? jeepunlimited ZJ Grand Cherokee Forum 15 04-23-2007 09:20 PM
Battery Volt Gauge UnDeR EsTiMaTeD ZJ Grand Cherokee Forum 3 12-16-2005 02:17 PM
