Is this the right position on the Battery Gauge - JeepForum.com
post #1 of 34 Old 07-09-2009, 10:41 PM Thread Starter
Casper4x4
Casper4x4's Avatar
I returned my battery and they gave me 80 bcks back so i paid the difference for a optima red top battery and she started right up! BUT I donno if this is a good sign.
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline
post #2 of 34 Old 07-09-2009, 10:44 PM
Bama_WJ
Bama_WJ's Avatar
Mine usually hovers more towards 14V.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #3 of 34 Old 07-09-2009, 10:45 PM Thread Starter
Casper4x4
Casper4x4's Avatar
hmmm im wondering if this alternator is not working correctly.
JCR 1 Ton steering
Flowmaster muffler
K&N air filter
Coleman roof rack
post #4 of 34 Old 07-09-2009, 10:56 PM
xJoshxx
2012 WK
that looks like your running off your battery turn off all your radios lights vents see if it rise's if it does Sounds like bad alt. If the alt is working right ive NEVER seen my volt meter swing or get that low even with everything on max. including all headlights and my kc's
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #5 of 34 Old 07-09-2009, 10:57 PM
jasn1981
I'm guessing alternator... I've barely dropped below 14V with a 3000watt stereo system, and 4 sets of HID's Running.
2002 WJ 4.7L V8 W/Selec-Trak: 2" OME Lift W/32's
Gibson Exaust, K&N Cold air intake
jasn1981 is offline
post #6 of 34 Old 07-09-2009, 11:02 PM
CMARJEEP
CMARJEEP's Avatar
Is that running or just with the engine off and the key in the on position? Your battery should be putting out just above 12V, so that would be about correct. When engine turns on the meter reads alternator output not battery voltage and should be around 14V with the engine running.
CMARJEEP is offline
post #7 of 34 Old 07-09-2009, 11:14 PM Thread Starter
Casper4x4
Casper4x4's Avatar
haha that was when it was running.. alright ill take the alternator back to the shop and have them give me a new one.
Thanks guys! Ahhh it feels good to have her up and running!
JCR 1 Ton steering
Flowmaster muffler
K&N air filter
Coleman roof rack
post #8 of 34 Old 07-09-2009, 11:17 PM Thread Starter
Casper4x4
Casper4x4's Avatar
i got bored... watcha think
JCR 1 Ton steering
Flowmaster muffler
K&N air filter
Coleman roof rack
post #9 of 34 Old 07-09-2009, 11:38 PM
jasn1981
If your really that bored you can pick a design for me to put on my bezel for my DD nav install.... I am thinking of Just WJ in a cool font, but I dunno....
I like the jump affect in the pic though..
jasn1981 is offline
post #10 of 34 Old 07-09-2009, 11:54 PM
tirus89
Where have you been Casper?
tirus89 is offline
post #11 of 34 Old 07-10-2009, 01:06 AM
the88thpianoman
2003 WJ
Looks really nice. I like it a lot.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #12 of 34 Old 07-10-2009, 02:14 AM
jeepemt
I think the old "take the neg cable off the battery and see if it still runs" will work on the GC. Try that. If it still is running then you got a good alt.
jeepemt is offline
post #13 of 34 Old 07-10-2009, 07:17 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
The battery gauge is actually an alternator output gauge when the vehicle is running. If it only shows 10 volts, then your alternator is not putting out enough power.
~James
ezflip is online now
post #14 of 34 Old 07-10-2009, 07:34 AM
xJoshxx
2012 WK
mine works with out the car being on and it shows 12-13volts with out starting it?
2011 WK2 ORA2 sold
xJoshxx is offline
post #15 of 34 Old 07-10-2009, 07:39 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Right. When the vehicle is not running, it does shows the battery power. But when the vehicle is running, your battery really isn't doing anything at all. Everything is powered by the alternator.
~James
Battery gauge drops after installing new serp. belt rookie79 ZJ Grand Cherokee Forum 13 01-22-2010 08:06 PM
Battery gauge and rpm's drop at idle, causing overheating im90gsx ZJ Grand Cherokee Forum 5 07-05-2009 03:28 PM
Gauge of battery cable RichP WK Grand Cherokee & XK Commander Forum 2 03-18-2009 03:54 PM
Tried new Battery ? gauge still falls ? jeepunlimited ZJ Grand Cherokee Forum 15 04-23-2007 09:20 PM
Battery Volt Gauge UnDeR EsTiMaTeD ZJ Grand Cherokee Forum 3 12-16-2005 02:17 PM
