Rich/White Exhaust - JeepForum.com
post #1 of 3 Old 06-09-2011, 05:57 AM Thread Starter
WileyRRE
Rich/White Exhaust
I have a 95 V8 5.2 and ive been have some exhaust problems....
Its blowing white smoke that just smells of fuel and the mpg is depressing. When I put my hand to it, it gets covered in what seems like fuel, also oil smells a little like gas, i noticed today a milky/creamy fluid too in exhaust tip .. it runs and idles just fine. Now when it was shipped from the states it need a jump and the guy the was so kind to hook the terminals backwards and popped a couple fuses don't know anything about my PCM. Its throwing a Code 27 but can get a straight answer for it...
Ive done a few things to it to try and fix it but being Italy id like to see what you guys have to say before i start digging deeper and buy big parts..
New spark plugs, wires, rotor/cap
New EGR valve, just the valve not the whole system- old was blown to ****
Checked fuel rail and Injectors
Checked the injector wires all send a signal
-thanks
Parker
WileyRRE is offline
post #2 of 3 Old 06-09-2011, 06:29 AM
newfieZJ
Parker , the code listed says one of the injectors isn't firing properly . I would check this out and confirm by holding a long screwderiver to the each injector , the other end to your ear , and listen for the clicks the injecter makes when firing .
Unforunately , the injector code does not specify which one .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 3 Old 06-09-2011, 07:41 AM
LordHobbit
white smoke = coolant. Possible blown head gasket.
check the injector as well.
Good luck, these are kind of a pain to find.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
exhaust , fuel , rich
Running rich, O2 replaced freakinheep89 ZJ Grand Cherokee Forum 15 10-18-2010 09:14 PM
95 GC V8 running rich camosilver ZJ Grand Cherokee Forum 1 09-17-2007 02:05 PM
Really rich after highway trip noreaga0221 ZJ Grand Cherokee Forum 9 08-11-2005 08:24 PM
Pearl White or White Jeep owners --- accessories/upgrades squid2004 ZJ Grand Cherokee Forum 19 01-15-2005 07:12 PM
How to keep the white tire lettering WHITE whitebomber ZJ Grand Cherokee Forum 7 10-30-2002 03:08 PM
