Rhino Liner for ZJ Cladding - Page 6 - JeepForum.com
post #76 of 96 Old 03-29-2006, 04:38 PM
jailbird1818
jailbird1818's Avatar
What about Line-X? My buddy is a dealer and he offered to do it for a case of beer. Has anyone tried the Line-X?
Thats my 2 cents, and I expect change.
[l_,[____],
l---L - OlllllllO-
( )_) ( )_)--)_)
jailbird1818 is offline
post #77 of 96 Old 03-29-2006, 04:43 PM
SET2JET
i'd say do it for sure
SET2JET is offline
post #78 of 96 Old 03-29-2006, 06:15 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
I've heard only good things. I say go for it.
WALTER
walter_da_jpr is offline
post #79 of 96 Old 03-29-2006, 07:54 PM
ERAUTreeTopFlye
ERAUTreeTopFlye's Avatar
Line-X is cool because it doesn't spray on hot like Rhino Liner. Lets you put the texture onto it that you want with the thickness that you want. Takes a day or two to dry. Problem is that they quoted meabout $600 to do it... the reason being that neither it nor Rhino liner are made to adhere to plastic. They said they way they'd do it would be to totally remove all cladding and put a coat on the entire piece so that it could sort of adhere to itself... kind of like a shell. Obviously more man hours and more spray to lay down.
Herculiner seems to be one of the better options out there unless you have boku $$ or, in the case above, know someone. I'd Line-X in a second if someone offered to do it for a case. Hell, I'd buy him two... of the good stuff.
Jon Selman
96 Jeep Grand Cherokee 5.2L
3.5" RE Lift on 31x10.5's
Daytona BEach, Fl.
ERAUTreeTopFlye is offline
post #80 of 96 Old 04-14-2006, 07:34 PM
anticrombie
anticrombie's Avatar
So is the general concencus that the herculiner roll on is the best to do the cladding and bumpers? I'm gonna do this sunday.
Charlie
anticrombie is offline
post #81 of 96 Old 04-14-2006, 10:49 PM
wh1te
wh1te's Avatar
1994 ZJ
What about duplicolor roll on I went in to a kragen/checkers whatever you want to call it. Looking to see the small spray cans of duplicolor vs the herc kit and they didnt have any spray duplicolor but had some stuff that said I could roll it on. Is this different or is this the same as the spray stuff
'94 ZJ Laredo Factory Tow Package
NP 231 "Command-Trac" Dana 35c 3.73:1 30x9.50x15 BFG A/T
2" BB
custom: radiator support/ tow points
wh1te is offline
post #82 of 96 Old 04-14-2006, 11:49 PM Thread Starter
mr_user
As stated previously, definetly go with the roll on stuff. The spray on stuff even with quality primer doesn't adhere to the cladding well at all. Believe me, I've been there - it required touch ups every month or so. Sun would bubble it, rain would take little pieces out, and when you knocked icicles off of the paint they would remove it.
Any roll on liner will suffice, I believe I used 3/4 gallon for the entire Heep.
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #83 of 96 Old 04-15-2006, 01:34 AM
wh1te
wh1te's Avatar
1994 ZJ
Ok will try the duplicolor roll on and let you know how it goes.
2" BB
wh1te is offline
post #84 of 96 Old 04-15-2006, 04:23 PM
anticrombie
Good deal, My tomorrow is set then!
Charlie
post #85 of 96 Old 04-15-2006, 04:45 PM
Virmagicus
Virmagicus's Avatar
How about removing the cladding . I was thinking about removing mine and then going with a tuff finish . I would imagine that there are holes for the mounts . What would be a good way to plug the holes for an even finish ?
Jeff
Virmagicus is offline
post #86 of 96 Old 04-15-2006, 04:49 PM
anticrombie
Originally Posted by virmagicus
How about removing the cladding . I was think about removing mine and then going with a tuff finish . I would imagine that there are holes for the mounts . What would be a good way to plug the holes for an even finish ?
When woody did his this way, he just put tape over top of the holes, and did a couple layers of liner on top of it. he says you can't even tell where the holes are.
Charlie
post #87 of 96 Old 04-15-2006, 06:31 PM
anticrombie
Well I just got back from Autozone. 96 dollars later I've got the herculiner kit in black. Tomorrow I'll have to pick up some acetone and a drill mixer. One final question....Cladding on, or off? If off, the what should I do about those little rivet thingys that stick out of the body?
Charlie
post #88 of 96 Old 04-15-2006, 09:00 PM Thread Starter
mr_user
Charlie, no need for the drill mixer - save the 15 bucks and stir it up by hand, it will do just fine. Also, I left the cladding on but if I could do it again I'd probably take it off. As far as the plastic rivets, you could pop those out of the body to expose small holes. Tape over the holes as Woody did, throw a few layers on, and you won't know the difference.
Good luck!
Matt
mr_user is offline
post #89 of 96 Old 04-15-2006, 09:04 PM
walter_da_jpr
We want to see it when its all done too.
WALTER
post #90 of 96 Old 04-15-2006, 10:13 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
Do not use the duplicolor stuff!!! It is definately not durable enough. I did the spray on inside a small trailer and cardboard boxes rubbed it off. I just did the roll on stuff on my sliders, 3 coats and after moving them around the backyard a few times there are huge flakes missing and chips - terrible products. I have the herc kit and will be doing the sliders over as well as where the cladding was and I'm thinking about the ARB as well. We'll see
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
rhino liner on zj wassy ZJ Grand Cherokee Forum 21 03-30-2009 03:41 PM
where to buy new cladding? uncc09meet ZJ Grand Cherokee Forum 10 12-06-2007 08:09 AM
Cladding micifus ZJ Grand Cherokee Forum 4 11-06-2006 08:48 PM
Wax on Cladding BarkleyBob ZJ Grand Cherokee Forum 5 01-01-2005 10:45 PM
