Revs real high like gas pedal is stuck! - JeepForum.com
post #1 of 15 Old 07-19-2011, 04:24 PM Thread Starter
D3V0311
97 grand cherokee laredo 4.0L 6cyl. select track 4x4.....131,000 miles...
aight so heres the low down, i drove to my parents house twice today (back n forth) to move some stuff, ran fine all day, soon as i was leaving turned it on like normal and the rpms went wayy up like i was stepping on the gas.thought it was odd so i just it off n started again. same thing as soon as put it into drive it jerked (such high rpms) but my foot was on the brake and the rpms went back down to about 1000. so when its in park or neutral itll rev super high but when in drive its fine..the issue is when i let off the brake the jeep wants to drive its self, it accelerates and even shifts fine but i dont have to even have my foot on the pedal... i looked to see if the throttle cable was stuck and it doesnt appear to be, also my display center is flashing like the battery went dead or disconnected, cables and terminals are really tight and clean, but all my radio stations are still preset...any body got any ideas of wtf is goin on?...no check engine light on
D3V0311 is offline
post #2 of 15 Old 07-19-2011, 07:12 PM Thread Starter
D3V0311
anybody got any ideass???
D3V0311 is offline
post #3 of 15 Old 07-19-2011, 07:28 PM
Ohno50
Could be the Idle air controller or an vacuum leak if it's constant
Ohno50 is offline
post #4 of 15 Old 07-19-2011, 07:34 PM Thread Starter
D3V0311
if i had a vaccuum leak wouldnt it act up when its in drive also?
D3V0311 is offline
post #5 of 15 Old 07-19-2011, 07:48 PM
Ohno50
It's just more noticeable with no load. It slams into gear when the RPMs are higher, but the then it's not as noticeable. Depends on how big the leak is. The higher RPMs means the engine is getting more air from somewhere. Which to me means IAC or a leak. IAC could be intermittent.
Ohno50 is offline
post #6 of 15 Old 07-19-2011, 08:18 PM Thread Starter
D3V0311
im gunna pull the IAC and check it here in a minute, how would i diagnose a vac leak or where one is at
D3V0311 is offline
post #7 of 15 Old 07-19-2011, 08:23 PM
Ohno50
Check all you vac lines. Look for a cracked/broken tube. Or a tupe tgat has been pulled from the intake. If it's bad enough you'll hear the hissing.
Ohno50 is offline
post #8 of 15 Old 07-19-2011, 08:34 PM
Candymancan
a vacumm leak would make a hiss if its really bad, and rpm's can be high when its leaking.
Candymancan is offline
post #9 of 15 Old 07-19-2011, 10:05 PM Thread Starter
D3V0311
could id screw up anything else if i drive it like this till i get it figured out..i have to have a vehicle to drive
D3V0311 is offline
post #10 of 15 Old 07-20-2011, 05:37 AM
Candymancan
I dont think so, just your gas mileage lol. How high is it reving exactly ?
post #11 of 15 Old 07-20-2011, 07:26 AM
melk
Pull off your battery cables to force the PCM to reset.
melk is offline
post #12 of 15 Old 07-20-2011, 07:32 AM
woodscavenger
1976 CJ5
Check the VIN, maybe it's really a Toyota
woodscavenger is offline
post #13 of 15 Old 07-20-2011, 08:08 AM
97zjdriver
It sounds like the tps. Had the same problem when I was in nc. It got wet and would idle realy high intill it was in gear. Bought one at the parts store for like 56 bucks but it fixed it. You could also try to put a hole in it to try to let it dyr out if it may have gotten wet
Sent from my Droid using JeepForum
97zjdriver is offline
post #14 of 15 Old 07-20-2011, 01:11 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
If it is slamming into gear it WILL destroy the transmission very soon. These transmissions don't take shock loads well at all.
Find the leaks soon or pay the price.
ratmonkey is offline
post #15 of 15 Old 07-20-2011, 02:08 PM
Midnightluckey
Ha. Give this man a beer.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
WJ 2000 4.7 Multiple High Revs On Startup Jerry1964 ZJ Grand Cherokee Forum 5 04-02-2010 07:30 PM
Heater blows warm at low rpm, hot at high revs? streetzj ZJ Grand Cherokee Forum 4 12-08-2009 01:48 PM
revs up without pressing gas pedal...... texasguy2000 ZJ Grand Cherokee Forum 7 11-11-2008 08:17 PM
WJ High Revs First 300 yards TORMULA ZJ Grand Cherokee Forum 12 06-03-2007 11:45 AM
Commander revs high after start Vizcad WK Grand Cherokee & XK Commander Forum 2 05-07-2006 12:12 PM
