Reverse lights - JeepForum.com
post #1 of 11 Old 04-05-2013, 01:35 AM Thread Starter
just_urd
Reverse lights
Don't know if any of you have the same issue, but is there an adjustment in the shifter in regards to the reverse lights? Intermittently they don't work, but if I creep the shifter towards neutral they come on, trans linkage maybe?
just_urd is offline
post #2 of 11 Old 04-05-2013, 02:53 AM
KoreaZJ
1994 ZJ
Please fill in your Jeep profile info. Helps others help you.
It displays...
<--- over there.
No adjustment just for REV lights. Shift cable may be slightly out of adjustment.
With engine off, press and release the button on the shifter handle while cycling through the gears. Determine if the shifter detent engages in the same position as the tranny detent.
Once the tranny is in a gear, while releasing the button, if the shifter tries to move forward/backward, then the shift cable needs adjusting.
If this checks good, then might have a bad Neutral Safety Switch on the tranny.
KoreaZJ is offline
post #3 of 11 Old 04-05-2013, 09:54 AM Thread Starter
just_urd
Thanks Korea, I'll try that. Updated my info as well, been using the mobile app, doesn't show up on my phone...
just_urd is offline
post #4 of 11 Old 04-07-2013, 08:39 PM Thread Starter
just_urd
So, this test checked out good. Probably look into a neutral safety switch some time soon. Thanks again for the advice.
just_urd is offline
post #5 of 11 Old 04-08-2013, 10:20 AM
Mickey_D
Stand by for sticker shock...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 11 Old 04-08-2013, 03:49 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the re series transmission nss is pretty cheap. just a plunger switch. the aw4 and 545rfe switches are insane.
ratmonkey is offline
post #7 of 11 Old 04-08-2013, 04:15 PM Thread Starter
just_urd
Yeah, I looked into it. Not expensive at all (44re).
just_urd is offline
post #8 of 11 Old 04-08-2013, 04:17 PM Thread Starter
just_urd
I noticed that I'm getting some leakage around the switch area as well... Could it maybe just need a good cleaning/snugging down?
just_urd is offline
post #9 of 11 Old 04-08-2013, 04:21 PM
Rich93ZJ
nss1.jpg $4.09
nss2.jpg $204.50
Hope you have the first one.
Rich93ZJ is offline
post #10 of 11 Old 04-08-2013, 04:52 PM Thread Starter
just_urd
Yes, I have the first one, just wiped the sweat off my forehead from the oh crap factor
just_urd is offline
post #11 of 11 Old 04-08-2013, 08:26 PM
Mickey_D
This is true. I was thinking of the one for my old XJ.
________________
#4
Mickey_D is offline
