Results of my Jeeps' trip to Florida!!! - JeepForum.com
post #1 of 6 Old 03-08-2004, 11:25 AM Thread Starter
ZJGuido
Junior Member
ZJGuido's Avatar
Well my family took a trip down to florida during this winter break and decided to take my Jeep, which i hesitated to give to them, considering that it already had 100,000 miles on it, but i had to.
My father told me that the Jeep performed well throughout the whole trip and had no complaints, but he recommended that i change the oil. So i took my Jeep to the shop and give it an oil change. As i lifted the Jeep up on the lift, i saw something no Jeep owner would ever want to see. To my surprise, i found five, thats right FIVE leaks that sprung during the trip, my luck !!!.
As i inspected the drivetrain, i found the following leaking:
1) Oil pan gasket
2) Oil filter housing
3) Seal bet. the trans. and transfer case.
4) Front diff. seal
5) Rear diff. seal
... and on top of all that, i found a trans. mount loose!! Its ironic that i've been bragging to everyone that my Jeep has 100,000 miles and it runs like new, with NO problems but found all this at once!!
Well, would anyone know how much i'm lookin' at here
Any ideas would be great, in order to restore my bragging rights!!!!
1998 Platinum ZJ 5.9 Limited
K&N FIPK / MOPAR ECU / Bilstein Shocks / H&R springs / Addco sway bars
ZJGuido is offline
post #2 of 6 Old 03-08-2004, 11:38 AM
Meerkat
1) Oil pan gasket
4) Front diff. seal
5) Rear diff. seal
The seals themselves don't cost a heck of a lot. I imagine you can buy all the seals you need for between $30.00 and $50.00. If you do the work yourself, you're not out much money. But if you are talking about paying somebody else to do it, then the price is going to skyrocket. I would expect a shop to charge around $585.00 in labor for all those jobs. That is just my own off-the-cuff estimate. Somebody with a flat rate book will be able to be much more exact.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 03-09-2004, 11:11 PM Thread Starter
ZJGuido
Junior Member
ZJGuido's Avatar
Thanxs for your reply. I figured that the labor was gonna get me.
As for the parts, since their cheap, I'm gonna go to the jeep dealer and buy them all at once.
As for the labor, i'm gonna replace the oil pan gasket and oil filter housing seals. I took a look at it and it wont be hard to change them, but the other stuff i'll have to pay someone . I never did jobs like that and i'm not gonna start experimenting on my car......... so i'm kinda stuck
Thanx again, at least now i have an idea on how much it's gonna be.
ZJGuido is offline
post #4 of 6 Old 03-10-2004, 01:35 AM
willsellout
The front and rear diff seals you should be able to do yourself as well as the housing seal. I have to do my housing seal this next oil change. The oil housing adapter seals are like 5 bucks..not to expensive and it should take about an hour to replace.. the other seals I have no idea about. Good luck though..the seals seem to be the main maintenence on jeeps.
Dan
willsellout is offline
post #5 of 6 Old 03-10-2004, 04:47 AM
Meerkat
I imagine you are intending to have the shop do the oil seal between the transmission and TC. While the seal itself is one of the easiest to replace (just drive it in with a big socket and hammer), getting to it is a real chore. That TC is heavy when you are laying on your back underneath the vehicle! The gaskets on the differentials come in a tube (silicone), I read the labels on all of the ones at Autozone, and ended up going with the blue stuff. Willsellout nailed it on the oil housing adapter. So really, the toughest one of the lot is going to be that oil pan gasket. It looks easy, but they usually don't let go very easily. Then you have to be sure your mating surfaces are immaculately clean with no gouges. It would definately be worth your while to find a known flat surface and make sure the lip on the oil pan is straight.
Good luck!
Warren
Meerkat is offline
post #6 of 6 Old 03-10-2004, 11:24 AM Thread Starter
ZJGuido
Junior Member
ZJGuido's Avatar
Well here's the deal. I had a friend of mine look at the Jeep and he said to replace the seal bet. the trans and the TC you have to remove the TC. Is this how it's really done, cause it looks to me that if you loosen up the trans. and TC, you can slide a new one in?
Also, are the seals that are used here like solid gaskets or liquid that needs to be applied?
As for the front and rear diff. seals, i'm talking about the ones that are located where the driveshaft goes into the differential. My friend told me that, in order to replace those, you have to take both axles out, the diff. assembly out and the driveshaft. That seems like it takes some skill to do.
ZJGuido is offline
CRD Oil Test Results wookiee WK Grand Cherokee & XK Commander Forum 24 02-05-2015 12:41 AM
Please look over my smog results snowmon ZJ Grand Cherokee Forum 5 12-31-2008 11:49 AM
results from larger TB on 5.2 tonysailor ZJ Grand Cherokee Forum 1 04-24-2005 03:03 PM
C/D Results for New Hemi det69 ZJ Grand Cherokee Forum 0 10-20-2004 07:47 PM
Oil Test Results JAURS ZJ Grand Cherokee Forum 3 12-07-2003 01:36 PM
