Resetting info center "0 Miles to Service"? - JeepForum.com
post #1 of 15 Old 12-27-2007, 10:38 PM Thread Starter
LargeFather
Exactly what resets the "0 MILES TO SERVICE" message on the info center? I know it reset when I changed the oil right after I bought it but all I did was drain it, R&R the filter, and refill with oil.
Thanks,
Scott
1995 Grand Cherokee Laredo, 4.0 liter, auto, 154K miles
1995 Dodge Ram 2500 2WD Turbo Diesel, converted from auto to 5-speed, BOMBED.....
LargeFather is offline
post #2 of 15 Old 12-27-2007, 10:41 PM
Gizimomo86
push both buttons on the info screen untill it resets itself - other wise it will beep at you every time you turn on your Jeep (its annoying let me tell ya haha) when its reset, it will give you 3000 miles untill you have to reset it again.
~Beth
Gizimomo86 is offline
post #3 of 15 Old 12-28-2007, 09:44 PM Thread Starter
LargeFather
Beth,
Thanks for the tip but it didn't work.
Anybody else?
Scott
post #4 of 15 Old 12-28-2007, 09:50 PM
Windowsrookie
No, that is the only way to reset it.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #5 of 15 Old 12-28-2007, 09:52 PM
driabyor
driabyor's Avatar
1994 ZJ
you have to get the screen to say miles to service then hold ONE of the buttons for a few seconds.. you will have to try both buttons one at a time, because I can't remember which one does what at the moment..it will then reset to what ever miles to service it was .. You can also change the amount of miles. somehow..
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #6 of 15 Old 12-29-2007, 12:08 AM
madcabbie
madcabbie's Avatar
Just go to setup where you can change your head light delay and door unlock settings..
To reset it...well honestly, i can never remeber...ill do it in the morning(after my oil change) and tell you...you either need to be on the screen that displays miles or in the setup menu
99 WJ
4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS|
Everytime Someone calls a Jeep, an SUV, GOD Kills a kitten.
madcabbie is offline
post #7 of 15 Old 12-29-2007, 12:17 AM
Gizimomo86
For some reason the last time I did it all I needed to do was hold both buttons for about 10 seconds...Ill pull the manual out tomorrow and double check
~Beth
post #8 of 15 Old 12-29-2007, 12:23 AM
CLNinja
CLNinja's Avatar
heres everything you need to know about the VIC
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #9 of 15 Old 12-29-2007, 12:43 AM
Gizimomo86
or that works too
~Beth
post #10 of 15 Old 12-29-2007, 09:47 AM Thread Starter
LargeFather
Got it! Also got to set the interval. Great help!
Thanks everyone!
Scott
post #11 of 15 Old 12-05-2012, 10:15 AM
Badfinger21
1994 FSJ Cherokee
Thank you so much for posting this this worked like a charm, I have been trying for a few weeks.
Badfinger21 is offline
post #12 of 15 Old 12-05-2012, 02:47 PM
CLNinja
CLNinja's Avatar
my pleasure... glad this post is still helping people 5 years after i posted it
Matt
CLNinja is offline
post #13 of 15 Old 05-13-2016, 10:28 PM
BertschElectric
BertschElectric
Re: 1995 Jeep Grand Cherokee Limited.
I tried various combinations like holding both buttons at the same time which didn't seem to work. Finally, I tried starting the engine, "0 Miles to Service" showed, I pressed and held Set briefly, then pressed and held Select briefly, then as I pressed Set again, the reset happened with "3000 Miles to Service".
BertschElectric is offline
post #14 of 15 Old 05-14-2016, 07:42 AM
98318242
Sounds like you're talking about a WJ, this is a ZJ.
98318242 is offline
post #15 of 15 Old 05-14-2016, 11:26 AM
kg6mov
Hears the voices
kg6mov's Avatar
Back when he was talking about it in 2007 the ZJ and WJ forums were the same thing, since then the forum has been split into individual forums for the different models (ZJ, WJ, WK, WK2). Unfortunately all the old posts are still in the ZJ forum.
kg6mov is offline
98 info center resetting? Pugliadoc ZJ Grand Cherokee Forum 4 11-15-2008 12:21 PM
Info Center Says "4WD Switch Needs Service" jvaughn ZJ Grand Cherokee Forum 2 08-28-2008 12:04 PM
Resetting the "Perform service light" firehawk ZJ Grand Cherokee Forum 4 11-26-2006 10:10 PM
clearing the "0 miles to service" hellrazor ZJ Grand Cherokee Forum 12 08-24-2006 10:03 PM
93GC Ltd Info Center display keeps resetting iroc22 ZJ Grand Cherokee Forum 1 08-11-2002 08:43 PM
