reseting the computer... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > reseting the computer...
TJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEBds fox ipf 2.0 racing series shocks now available at rock
Unread 11-11-2006, 02:13 PM   #1
GRDCHRKE555
alright. yes i know that you can reset the engine computer orrr PCM or whatever but disconnecting the neg. side of the battery. but instead i would like to rest it without screwing with my radio settings on my pioneer HU. can i pull a fuse that will reset it? and also which fuse would it be. i tried but i didnt see any that really related to the engine computer. i have a 99 wj 4.0 if that changes anything.
GRDCHRKE555 is offline   Reply With Quote
Unread 11-11-2006, 03:35 PM   #2
GRDCHRKE555
any help anyone? there has to be some other way of reseting the PCM
Unread 11-11-2006, 03:54 PM   #3
-Joe-
Is it really such a big deal to reprogram your stations?
Ive seen an adapter with a 9v battery that plugs into your cig lighter plug and saves your radio settings when you disconnect the battery..
Was either in a summit catalog or a harbor freight one..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Unread 11-11-2006, 04:06 PM   #4
GRDCHRKE555
its not the radio stations that it resets cause i rarely listen to the radio since i have my cd's goin. it messes up all of the EQ settings. the custom one i made. plus all the other preset ones by pioneer and some other things. thats why i was wondering cause its not easy to fix according to best buy
Unread 11-11-2006, 04:31 PM   #5
greasefingers
1994 ZJ
Yes pulling the fuse is a smart way to clear the PCM. However, I like removing the battery cable as it forces me to clean them, which should be done once a year.
In the pic below there is a full row of three mini fuses.(yellow, yellow, red) The center yellow one (20 amp) is the one for the PCM/ECU. Underneath the cover is a bunch of labels. PCM is not one of them, but engine control is. That’s the one. I mention this as the pic is for a 1994 power distribution center and newer one may be different.
Sorry for the out of focus shot, but it is dark outside right now.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 11-11-2006, 09:54 PM   #6
GRDCHRKE555
thanks.... i just unplugged the batt. this last time. but from now on ill do that.
