reset check engine light? 95 ZJ - JeepForum.com
post #1 of 5 Old 03-14-2013, 11:27 AM Thread Starter
phishy
I see all sorts of threads on checking trouble codes...and i've replaced my 02 sensor, intake air temp sensor, map sensor and fixed a vacuum line for the EGR which should take care of all of my codes. I've disconnected the battery and that didn't do reset the light...so is there a different way?
phishy is offline
post #2 of 5 Old 03-14-2013, 11:48 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
if that didn't reset the light then it thinks you've still got broken sensors. check the codes and post em
ratmonkey is offline
post #3 of 5 Old 03-14-2013, 01:18 PM
dnuccio
doesnt it have to go thru a certain number of key cycles to reset?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 5 Old 03-14-2013, 01:33 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if you fixed it and just let it go. if you disconnect the battery it should clear all memory within a few minutes.
post #5 of 5 Old 03-23-2013, 11:42 AM Thread Starter
phishy
It turns out there was still a bad sensor. The intake air temp sensor i replaced like 8 months ago was bad again. I replaced it and the check engine light went right on off. Jeep is running so much better now. No more surge in the idle. Also had a bad battery...was having some weird starting issues. Sometime today I'm going to do an oil change and a tune up...and flush the cooling system out.
phishy is offline
