Replacing Shaft on Power Antenna - JeepForum.com
post #1 of 9 Old 06-01-2004, 01:07 PM Thread Starter
dpierson
I am about to order a new shaft for my power antenna on my 94 GC after it suffered the wrath of the car wash (it was stuck in the up position anyway). Since the motor seems to be good still I am hoping to replace just the shaft and the nylon cord. Anyone have any tips or tricks? I know how to get the antenna out from the fender but I am trying to avoid getting halfway into it and finding that I don't know how to change the shaft itself.
dpierson is offline
post #2 of 9 Old 06-01-2004, 01:49 PM
jrcaz7
jrcaz7's Avatar
I have a similar thing. I hear the motor turn but the antenna doesnt go anywhere
1994 YJ Sahara.
2'' BDS, 1.25'' Shackle, 31x10.5'' BFG Mud Terrain's mounted on black 15x8 Cragar Soft 8's.
1995 ZJ begging to be lifted.
jrcaz7 is offline
post #3 of 9 Old 06-01-2004, 01:57 PM Thread Starter
dpierson
I know that these tend to go bad, either corossion on the shaft itself or the nylon cord goes bad. When the shaft broke on mine I examined the nylon cord and found many of the teeth broken and worn, not too surprising for something ten years old. Since the motor seems to work everytime I power it on and off I figure that it is worth a shot at replacing just the shaft with a new cord. I'm just wondering if getting the new shaft to interface with the motor will be an issue.
dpierson is offline
post #4 of 9 Old 06-01-2004, 06:03 PM
TheOle34
TheOle34's Avatar
saw them on ebay for 25$..
how much at the jeep stealership??
mine goes down all excwpt for the bottom shaft... so i have a stubby antenna when it is in down position.
if the teeth are not jammed inside it is an easy replace. otherwise you have to open it up.
robbie
'96 GC Laredo 191,500+ Miles - 6 Cyl. Break-in Period.
'93 GC Laredo w/ everything but leather. 5.2L V8--- Rolled and Wrecked!!!
Robbie "TheOle34"®™
N40° 45.232 W73° 01.394
TheOle34 is offline
post #5 of 9 Old 06-01-2004, 06:08 PM Thread Starter
dpierson
robbie
Robbie,
I just ordered a new shaft with the nylon cord and new gear for $22 with shipping. Check here: http://www.lafayetteradio.com
I'm going to try and work on this this weekend if it arrives here on time and I'll post some pictures and instructions based on what I was able to do.
dpierson is offline
post #6 of 9 Old 06-01-2004, 06:14 PM
TheOle34
TheOle34's Avatar
nice
i'll check back. we did a replace on a buddys and it was simple. he paid 30$ thru a speed shop. turned radio on undid nut and slid right out. threaded and turned radio off. replaced nut and done!!! 10 minutes. 1 on scale of 1-10 difficulty.
robbie
Robbie "TheOle34"®™
TheOle34 is offline
post #7 of 9 Old 06-02-2004, 08:50 AM Thread Starter
dpierson
Antenna Cap Nut
I was looking at this last night, any suggestions on how to get the cap nut off without scratching the hell out of it? If I understand correctly this is threaded on to the motor. It has those three slots, any kind of wrench that fits this?
dpierson is offline
post #8 of 9 Old 06-02-2004, 08:55 AM
TheOle34
TheOle34's Avatar
we used (i believe) a black n decker locking wrench. it is rubber coated and funky looking. my buddy does car finishing on show rides. he always has the "right" tools. i'll post a pic if possible.
Robbie "TheOle34"®™
TheOle34 is offline
post #9 of 9 Old 06-02-2004, 10:45 PM
Rocks
If there's enough of the nylon toothed strap to grap hold of, it's very easy. Chances are that there's a 3-4 inch piece stuck in the gearbox of the antenna motor. In that case you're going to need to remove the rear right wheel well cover and access the antenna motor. Finding the connector under the dash was impossible, so I wound up cutting the wires then using 3M connectors to spice them back together. However, by just loosening the antenna motor and turning it, you can remove the plastic gearbox cover and extract the broken piece of nylon, then insert the new nylon gear cord per the package instructions.
Rocks is offline
Replacing the Power Antenna JeepinDK ZJ Grand Cherokee Forum 12 11-10-2012 02:35 PM
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 09:53 AM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 09:17 PM
WJ – Power antenna jeep_on ZJ Grand Cherokee Forum 2 05-16-2006 03:04 PM
93 ZJ power antenna coax and power disconnect location popeye ZJ Grand Cherokee Forum 1 01-11-2004 06:33 AM
