replacing rear window glass - JeepForum.com
post #1 of 3 Old 08-16-2009, 08:29 PM Thread Starter
wickerham
One of my first posts on here was "how to remove old tint". You see the stealership did a crap job removing the purple junk the previous owner had on. They got all but the rear glass removed. They peeled the rear tint up and only one layer came off. Months later now, I'm still "chipping" away at this ugly, blurry, purple mess on my back glass. Well, I've had more than enough!
How hard is it to remove rear glass from my "donor" 95 ZJ then install it on my 93 ZJ? I'd like the defrosters to still function. Both rear windows DO have them.
wickerham is offline
post #2 of 3 Old 08-16-2009, 11:46 PM
driabyor
driabyor's Avatar
1994 ZJ
they probably left it on so they would screw up the defroster grid...
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 3 Old 08-17-2009, 03:55 AM
j.love
j.love's Avatar
1994 ZJ
you need to find a source for the rubber seal. when you find a cheap source, let me know.
then just cut the rubber from the outside and the glass will fall out.
I did the side windows on 2 part outs, same rubber as the rear hatch, still have them sitting on the shelves. But, I cut them from the inside between the body and the rubber seal. what a pain in the butt! If I have to do it again, I will just cut the seal off. and then peal the used seal off the body once the glass is out.
the defoger strips have a wire connector that is easily removed once you look at it you will see that its no sweat to deal with.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
Replacing outside rear view mirror glass Thomas_Jeep WK Grand Cherokee & XK Commander Forum 6 01-30-2009 07:13 PM
Door window glass adhesive? MAUSS ZJ Grand Cherokee Forum 3 09-06-2006 05:23 AM
Detaching window glass from '02 window regulator? dotspace ZJ Grand Cherokee Forum 3 08-04-2005 07:23 PM
Busted window(not glass) 01grander ZJ Grand Cherokee Forum 11 05-03-2005 02:09 PM
Need new window glass, tinted ddombrowski WJ Grand Cherokee Forum 1 05-08-2004 10:05 PM
