Replacing Rear Lower Control Arm? - JeepForum.com
post #1 of 16 Old 05-09-2012, 01:13 PM Thread Starter
dgilluly
Today I was looking at the rear shocks to see how to replace them, I think I discovered a more serious problem. It appears that the rear lower control arm(passenger side) cracked right through to the rubber bushing. I can stick my pinky right into the crack and feel rubber. Anyone know how to change these? I don't want to drive it very far knowing that it's not safe for the road.
I'm a college student and self-employed computer technician.
CompTIA A+ certified, and soon to be CompTIA Network+ certified as well
I currently own a 1995 Jeep Grand Cherokee, pretty much all stock instead of the sound system.
dgilluly is offline
post #2 of 16 Old 05-09-2012, 01:15 PM
PeriwinkleZJ
Two 21mm bolts. Should new able to just unbolt or and bolt it right back in. If not using a jack to move the axle up and down should align it.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:
PeriwinkleZJ is offline
post #3 of 16 Old 05-09-2012, 04:34 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
coralman is offline
post #4 of 16 Old 05-09-2012, 04:41 PM
TheHalfWit
Bwahaha, you think that will just unbolt like that?
You must be joking, Mine were that bad and it took a 3 foot cheater bar and I soaked them in penetrating oil for a couple of weeks in advance.
My advice would be look into getting a red wrench, it will speed things up immensely.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #5 of 16 Old 05-09-2012, 04:47 PM
jtackerman28
Mine were easy to run off with an electric impact wrench.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #6 of 16 Old 05-09-2012, 04:48 PM
biggoofy
Mine come out easy just needed a ratchet and socket.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #7 of 16 Old 05-09-2012, 04:51 PM
TheHalfWit
My point is that is so rusty that the shell has rusted clean away. That bolt will be seized in there like a son *****, now I can take mine out with a ratchet but the original bolts didn't come out with an impact wrench.
Calm. C.
post #8 of 16 Old 05-09-2012, 04:54 PM
jtackerman28
If he cleans it enough before he can probably get the out. A can of pb blaster and a lot of wire brushing
post #9 of 16 Old 05-09-2012, 05:21 PM
hdrocknroll
I used atf & acetone mix the day before, then an impact wrench, the nuts came right off.
You need to set it on the ground when you tighten them up.
You can replace the bushings or, for a little more money the whole c arm, Rock Auto has the parts.
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #10 of 16 Old 05-10-2012, 01:59 PM Thread Starter
dgilluly
I'll probably use the impact wrench on it. I've always had good luck doing that but sometimes breaks the bolts and then I usually just pounded them out. When I do these kinds of repairs myself, I usually get replacement bolts and nuts. Sometimes I have to use heat to get them out as well. I stopped by advanced auto parts today and they don't even have them in stock, so I'll probably be making a trip to autozone or napa in the next couple of hours.
dgilluly is offline
post #11 of 16 Old 05-10-2012, 05:06 PM Thread Starter
dgilluly
Couldn't find the parts locally, I'll probably end up ordering it from rock auto. But looks like the arm will stay on with a closer inspection, the side parts of the control arm are still in tact, and will still hold it to the bushing though it may result in uneven wear. If need be I'll see if I can get one of my friends to weld it while I wait for an order to come in. I'm still going to change the rear shocks(They needed to be changed anyway.), just bought a pair of guardian pros.
dgilluly is offline
post #12 of 16 Old 03-11-2016, 03:42 AM
Pameela
All of the forces that accelerate the car, as well as much of the braking loads, pass through the rear lower control arms. In stock form, the excessive deflection allowed by the original rubber bushings prevents the rear axle from maintaining its correct position under the chassis. The axle is allowed to shift forwards, backwards, and sideways under the car, leading to poor traction and poor handling
Pameela is offline
post #13 of 16 Old 03-11-2016, 03:57 AM
kg6mov
Hears the voices
kg6mov's Avatar
4 years late to the party much?
kg6mov is offline
post #14 of 16 Old 03-11-2016, 04:54 AM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum!
wingless is offline
post #15 of 16 Old 03-11-2016, 04:56 AM
USSENTERNCC1701
1994 ZJ
That's a feature, not a bug.
USSENTERNCC1701 is offline
arm , control , rear , zj
rear lower control arm help..... bustaone ZJ Grand Cherokee Forum 9 03-22-2011 08:14 PM
BDS Lower rear control arm curve - up or down? Coletrickle ZJ Grand Cherokee Forum 1 11-18-2009 12:59 PM
Any DYI on replacing ft and lower control arms,rear ca and track bar? 333hpdog ZJ Grand Cherokee Forum 6 04-19-2009 05:04 PM
Rear Lower Control Arm King Lerado ZJ Grand Cherokee Forum 8 09-07-2008 08:22 PM
94' GC limted replacing upper and lower control arm maryella ZJ Grand Cherokee Forum 6 10-11-2004 08:51 PM
