replacing quadra track on jeep with selected track from old jeep - Page 2 - JeepForum.com
post #16 of 31 Old 07-09-2014, 09:37 PM Thread Starter
derekroth91
My thought was joints of some such. How does the front axle get power with out the front drivetrain
derekroth91 is offline
post #17 of 31 Old 07-09-2014, 09:39 PM Thread Starter
derekroth91
Well that could be a solution too. How does the front axle get power with the drive train taken out? By some other means? Sorry about the double posting
post #18 of 31 Old 07-09-2014, 10:35 PM
kg6mov
Hears the voices
kg6mov's Avatar
The vc controls power going to the front wheels in normal operation. In 4lo the axles are locked together by other means in the transfer case.
kg6mov is online now
post #19 of 31 Old 07-09-2014, 10:40 PM Thread Starter
derekroth91
How much would the shop charge for labour for transfer case swap
post #20 of 31 Old 07-10-2014, 08:31 AM
WhiteOut
WhiteOut's Avatar
No one can answer this except the shop you use.
WhiteOut is offline
post #21 of 31 Old 07-10-2014, 08:32 AM
mig1289
Id guess around 350. I'm going at rate of 80-120 hr depending on the shop. Do it yourself in a weekend
2wd zj...
mig1289 is offline
post #22 of 31 Old 07-10-2014, 09:49 AM
T-nave
If I were in your shoes I would (or have somebody) just replace the viscous coupler and be done.
9er, 3.5 IRO lift + 3/4" spacers w/ adjustable trac bars and arms, 242 swap, 285/70/17 Duratracs and some other doo dads
T-nave is offline
post #23 of 31 Old 07-10-2014, 03:04 PM
Timo_90xj
Timo_90xj's Avatar
^- this. The best option on a daily driver that is used on the trails every now and then. 249 AWD on slippery weather is a LOT better than the 4 full time on the 242.
Also, as was already mentioned, if 4wd is only needed for trail runs and RWD is enough in daily use year-round, keep the front DS bolted in and remove the VC from inside the transfer case. This will leave you with RWD, and locked 4wd LO.
***Under construction***
Timo_90xj is offline
post #24 of 31 Old 07-11-2014, 09:37 AM
iann32
Originally Posted by phitmein View Post
Wouldn't the clicking be from front CV joints on a 98 ?
Thats what I would say it is.
iann32 is offline
post #25 of 31 Old 07-11-2014, 11:34 AM
T-nave
Yep. Sounds like he needs some axle joints too!
T-nave is offline
post #26 of 31 Old 07-11-2014, 11:41 PM
baron46
Why does the book say NOT to Drive with front axle off of Transfer case on my '96 249 Transfer case. Something to do with the viscous coupling??
baron46 is offline
post #27 of 31 Old 07-12-2014, 04:28 AM
Timo_90xj
Timo_90xj's Avatar
Do you mean front driveshaft? No issue on the '96-'98 ZJs with the front DS removed. Only on the '93-'95 you should not remove the front DS with the 249 TC.
post #28 of 31 Old 07-13-2014, 09:53 AM
baron46
I guess I should have asked WHY cannot the front DS be disconnected? However I do have a '96 and a 249 with a VC and now I do't have to worry about disconnecting it to eliminate that awfully annoying whining upon deceleration. As I understand it the pinon bearing in the front diff needs replacing !! And an axle shop is the only way to go!!
baron46 is offline
post #29 of 31 Old 07-15-2014, 06:15 PM Thread Starter
derekroth91
Without the vc how are the axles locked for trail runs. Tranny shop said 150 to 200 for the swap if I took the one out from my 96 myself. Do I need new axle joints? In addition to the CV joint?
Its not shaking at 45 with a constant squeak that gets worse the faster you go. I can hear scattered squeaks at lower speeds but not nearly as bad when shaking.
post #30 of 31 Old 07-16-2014, 01:18 AM
Timo_90xj
Timo_90xj's Avatar
4lo works because power does not go through the VC to front wheels when in 4lo on the '96-'98 249.
