Replacing power door lock actuator instructions? - JeepForum.com
post #1 of 4 Old 11-16-2011, 06:14 PM Thread Starter
citRon
2003 KJ Liberty
Anyone got a good link to instructions or a write up on replacing the power door lock actuator on a door?
My driver's side front door doesn't lock/unlock with the remote, but the other three do 100%. It used to move about 1/4" when I hit the button, then it died altogether. I have the interior panel off to replace it with one that someone didn't chew on, so I'm going to replace the actuator while I'm in there- going to the junkyard tomorrow.
With all the rods and such, I want to do it right the first time. My Haynes manual is useless for this...
citRon is offline
post #2 of 4 Old 11-16-2011, 07:15 PM
Smokey1r
The only real pain in doing this is releasing the rod latches, 2 of them can be rather difficult to get out if you don't have small hands so tools to get in there might be required and you will have to manipulate the assembly out of the door panel once its all free, be patient and you will get it!!!
From the factory service manual regarding the door latch.
FRONT DOOR LATCH
REMOVAL
(1) Remove door trim panel and waterdam.
(2) Remove door latch retaining screws (Fig. 18).
(3) Disconnect all rods from door latch (Fig. 19).
(4) Disconnect wire connector, if equipped.
(5) Remove door latch from door.
INSTALLATION
(1) Reverse removal procedure. Tighten latch
screws to 10 Nm (95 in. lbs.) torque.
Smokey1r is offline
post #3 of 4 Old 11-16-2011, 09:23 PM
ZJ1010
If you find a used actuator post up where you got it. I've been looking around here, Albuquerque NM and haven't found one
ZJ1010 is offline
post #4 of 4 Old 11-17-2011, 04:53 AM Thread Starter
citRon
2003 KJ Liberty
cool- thanks! ...and will do. The dealer wants $136.00 for one.
citRon is offline
Power Lock Actuator (I think!) geekycamper ZJ Grand Cherokee Forum 2 10-23-2006 10:12 AM
Rear hatch power door lock actuator - NEED SOURCE fpfiglia ZJ Grand Cherokee Forum 4 10-20-2006 08:57 AM
Anyone Taken Off the Power Lock Actuator CrawfishStu ZJ Grand Cherokee Forum 2 01-15-2006 10:10 PM
Power Door Lock Buzz / Door Lock Duck Noise - Power Door Lock Actuator Solution Coppell-Jeep ZJ Grand Cherokee Forum 4 01-11-2006 10:25 PM
Help replacing D/S door lock actuator switch! smclarke ZJ Grand Cherokee Forum 2 07-11-2005 05:39 AM
