Quantcast Replacing Oil Pan? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Replacing Oil Pan?
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 12-27-2009, 04:57 PM   #1
Khun
Replacing Oil Pan?
My step dad tried changing my oil while I was out of town, and being the non handy man he is, tries forcing the drain plug out and I don't know how he did it, but now it is neither tight or loose. It's so loose that oil is dripping constantly down.
I brought it to Jeep, they said that I needed to get a new oil pan installed and quoted me at 650-something for both pan and labor. I looked up the price of the oil pan, and it was about $100. Are they trying to rip me off?
Would it be better if I just buy the oil pan and get it installed at another auto shop? How much would that approximately be? Or is it simple enough to do at home? Would I need to lift the engine to get the oil pan out? Would I have to also purchase a new oil pan gasket as well?
car info:
2004 Grand cherokee
4.0L
oil pan from autozone : http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?skuDescription=Spectra+Premium+/+Oil+Pan&categoryDisplayName=Internal+Engine&fromS tring=search&itemIdentifier=220526_22082_9459_&pro ductId=220526&sortType=&parentId=51-0&filterByKeyWord=oil+pan&isSearchByPartNumber=fal se&navValue=15100961&categoryNValue=15199999&fromW here=&itemId=961-0&displayName=Oil+Pan&store=3042&searchText=oil+pa n&brandName=Spectra+Premium
Oil pan gasket from autozone: http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?skuDescription=Felpro+/+Oil+Pan+Gasket&categoryDisplayName=Internal+Engin e&fromString=search&itemIdentifier=74438_95350_0_& productId=74438&sortType=&parentId=51-0&filterByKeyWord=oil+pan&isSearchByPartNumber=fal se&navValue=15100529&categoryNValue=15199999&fromW here=&itemId=529-0&displayName=Oil+Pan+Gasket&store=3042&searchText =oil+pan&brandName=Felpro
Khun is offline   Reply With Quote
Old 12-27-2009, 05:15 PM   #2
FrankTheDank
i dented my oil pan and removed it to pound out the dent and make sure i didnt mess anything else up.......
there is like 30+ little bolts holding the pan on, some will require a long extender and a deepwell socket. if you replace it on your own you will also need to replace the gasket. i didnt have to raise the engine, although my 4+'' of lift helped get under there i still had to disconnect the trackbar on the frame mount side in order to finally get the pan to slide out. i did this by myself with simple hand tools in my garrage. took like 8 hours and was the messiest thing i have ever had to do under the jeep.
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::4'' IRO LA::32'' Retreads::IRO T case skid::KOR Light Bar & Tie Rod::
::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Go Berzerk Winch Bumper::Smittybilt XRC8::
I don't need to lie...that way I never have to remember what I said
FrankTheDank is offline   Reply With Quote
Old 12-27-2009, 05:16 PM   #3
FrankTheDank
http://www.jeepforum.com/forum/f13/dented-my-oil-pan-913717/
from when i pulled mine, may be some helpful info in here
Old 12-27-2009, 06:43 PM   #4
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Don't make more of a production out of this than it really is. Oil change places strip the plugs all the time.
Your drain plug should be 1/2-20 thread. What you need is a self tapping oversize drain plug, such as:
O'Reilly Auto Parts
or
O'Reilly Auto Parts
Make sure you put a gasket on there.
I've seen all kinds of devices that do the job. Go to your local Pep Boys or NAPA, etc and ask.
-Steve
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline   Reply With Quote
Old 12-27-2009, 06:54 PM   #5
cmonson
exactly as above said. Stripped drain plugs are common. Buy an oversize plug and tap it.
It will be a 30 min fix.
1. drain oil
2. tap drain plug
3. Replace with oversize plug.
here is another thread. Probably one of many:
http://www.jeepforum.com/forum/f12/oil-drain-plug-44397/
cmonson is offline   Reply With Quote
Old 12-28-2009, 07:40 PM   #6
Khun
sjz - so with those plugs all I have to do is insert?
Old 12-28-2009, 08:09 PM   #7
cmonson
tap it first, then insert. Put some grease on the tap to collect the filings. It will take 5 mins.
Old 12-28-2009, 08:21 PM   #8
SJZ
SJZ's Avatar
They are self tapping (notice the "split end"), but putting grease on them, as stated above, isn't a bad idea to catch the chips. Then pull it out, wipe off any chips, put 'er back in with a gasket & fill'er up.
-Steve
Old 12-28-2009, 08:32 PM   #9
Khun
oh okay. Thank you very much for all the info.
Glock Forum
