Replacing my PCM - Page 2 - JeepForum.com
post #16 of 31 Old 04-18-2013, 08:49 AM Thread Starter
ZJNewbi3
The lights were going to go on the day it died Thanks for the connector! Trying to dig for that picture for weeks! I have a Haynes Manual and a download of a 1997 ZJ FSM that lists 4.0L, 5.2L, and diesel engines. Any place I can get a FSM for my 1995 ZJ 5.2L?
So far I'm going to check:
Grounds
o2 Sensor wires
PCM Connector (Pins: 3,6,7,11,12)
When I check the pins i should get:
12v on 3
5v on 6
8v on 7
and what on 11 and 12?
ZJNewbi3 is offline
post #17 of 31 Old 04-18-2013, 12:48 PM
ZeeJay1997
Measure resistance from pin 11 and 12 to the negative battery post, not the terminal. Put meter on lowest ohm scale. If you get anything besides zero ohms, there is a problem. Be sure to measure the resistance of the meter leads by touching them together.
ZeeJay1997 is offline
post #18 of 31 Old 04-18-2013, 12:56 PM Thread Starter
ZJNewbi3
Got it! Thanks everyone! Still didn't rain yet today!
ZJNewbi3 is offline
post #19 of 31 Old 04-18-2013, 03:52 PM Thread Starter
ZJNewbi3
Just back probed the computer (old one) think I'm not getting power will post pics ina bit here (not sure if I'm doing it right)
ZJNewbi3 is offline
post #20 of 31 Old 04-18-2013, 04:33 PM Thread Starter
ZJNewbi3
Here are pics!!! Purple/white (5v) first then black/white (8v) the pink/black (12v) got 0.9V when tested the same way.
When I tested grounds I used the setting so the meter will beep when its a circuit. On pin 11 to battery negitive I got a beep. On pin 12 to battery negitive I DIDN'T get a beep.
I'll try to post vids to YouTube later of this. Also I found grounds on the motor on passengers side, under the alternator, infront of head gaskets. These both beeped with the same ground test used with the PCM. The connections looked good, clean and tight. Only iffy thing is the rusty bolt holding them in.
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #21 of 31 Old 04-18-2013, 04:45 PM Thread Starter
ZJNewbi3
Also I looked at the o2 (I think) its the only wires I found near the exhaust and its also near the oil filter it looks like? But it looks fine. Also the meter is set at "20" on the DC side thought you could see it. The battery was at 11.97V
ZJNewbi3 is offline
post #22 of 31 Old 04-18-2013, 06:09 PM Thread Starter
ZJNewbi3
Here are vid links (no audio sorry) READ DESCRIPTIONS
Testing ground:
Testing power:
ZJNewbi3 is offline
post #23 of 31 Old 04-18-2013, 07:17 PM
ZeeJay1997
Your videos say they are private.
If the ground on pin 12 is missing as demonstrated with no beep, the circuit it is associated with inside the PCM will not function. This is probably why you are getting no voltages.
Check resistance the way I recommended earlier. Most of those meters are set up to beep at a threshold resistance, some up up 40 ohms. I spent a few days on a hot flight line working on a broke airplane everyone wanted fixed now because i was relying on the beep for continuity check. I hate the beep.
Take the grounds on the block apart and clean them. Takes 30 minutes.
post #24 of 31 Old 04-18-2013, 07:21 PM Thread Starter
ZJNewbi3
Funny story...my uncle stopped by to give a hand and out of the blue he decided to test all the fuses...well one of mine were blown -.- put a new one in and all the powers to PCM come back and I have power to fuel pump. How can I tell? Well lets say my crappy teen-age rush job didn't go to well and gas goes everywhere...have to drop the tank and fix the lines I LEARNED A GOOD LESSON HERE! After I fix that its back to re-testing all the sensors and for spark and such.
THANK YOU ALL FOR ALL OF THE SUPPORT! It's really much appreciated! Didn't grow up working on vehicles much and now I get to get my hands dirty. After I get this thing up and running again hopefully I'll start a build thread!
ZJNewbi3 is offline
post #25 of 31 Old 04-18-2013, 08:41 PM
JohnCrabtree
1994 ZJ
Oooopsie! Haha! We've all done something similar, no worries!
JohnCrabtree is offline
post #26 of 31 Old 03-01-2014, 12:37 PM
squinty22
1994 XJ Cherokee
Hey guys I`m a newbe here.First time on forum and still learning how to get around here.I have a 94 GC 5.2.Went thru the whole bit with the no start no spark at coil and distributor, no fuel pump ,and no cel.Got most of that fixed.Found previous owner did some rewiring for the alternator and redid the caps in the ecu.I replaced the fuse block,cps.coil,and ecu.All used except the coil and cps.I now have cel,cranks and starts but dies right away.Like a security issue.There is no security light on in the dash.Starts right up then dies in 2-3 seconds.Any help would be appreciated.Most of the stuff I did was from reading hours of post on here.
squinty22 is offline
post #27 of 31 Old 03-01-2014, 01:31 PM Thread Starter
ZJNewbi3
Did you look to see if you have the security wire in the door? I read articles on here telling you how to ground it out so your security will not work but you will get the jeep to run. Search "grounding security zj" in google maybe?
ZJNewbi3 is offline
post #28 of 31 Old 03-01-2014, 02:33 PM
squinty22
1994 XJ Cherokee
i did that already. does the same thing.If the ecu that I got is from a non security vehicle will it work on this one that has security?
post #29 of 31 Old 03-01-2014, 03:43 PM Thread Starter
ZJNewbi3
Not sure honestly.
ZJNewbi3 is offline
post #30 of 31 Old 03-02-2014, 06:48 AM
squinty22
1994 XJ Cherokee
Anyone else have any good ideas.I don`t want to buy a new ecu to find out that was not my problem.The other thing is the ecu I got from the salvage yard has not had the caps done.Do any of you think this would be worth a shot.Thanks again.
ecu , no start , pcm
