Replacing my PCM - JeepForum.com
post #1 of 31 Old 04-17-2013, 08:53 AM Thread Starter
ZJNewbi3
Replacing my PCM
I'm replacing my PCM in my 1995 5.2L V8 Limited today and was wondering if I need to flash the new computer or not? There is no sticker on my old one saying I need to and the instructions that came with the new one said "you may need to". I've been 3 weeks without my ZJ and I need this thing to run so I'm hoping for plug and play!
Also is there any re-learn process or anything else? I plan on testing the voltages on my old PCM to confirm that it is dead then disconnecting the negative terminal on the battery then pop in the new PCM reconnect the battery and start it up. If it doesn't work the thunder storms tonight will put out the flames...
ZJNewbi3 is offline
post #2 of 31 Old 04-17-2013, 09:31 AM
JohnCrabtree
1994 ZJ
Anytime you disconnect a battery cable your electronics will reset. Which means that there will be a relearning process but that just means you start it and let it idle for a few minutes when you reconnect the battery.
JohnCrabtree is offline
post #3 of 31 Old 04-17-2013, 10:23 AM Thread Starter
ZJNewbi3
Great! does the new PCM need to be flashed though?
ZJNewbi3 is offline
post #4 of 31 Old 04-17-2013, 12:07 PM
JohnCrabtree
1994 ZJ
Sorry, i dont know the answer to that
post #5 of 31 Old 04-17-2013, 12:45 PM
Bigdjs123
It depends on the pcm that you baught. Where did you get it?
Bigdjs123 is offline
post #6 of 31 Old 04-17-2013, 01:34 PM Thread Starter
ZJNewbi3
rock auto
ZJNewbi3 is offline
post #7 of 31 Old 04-17-2013, 01:44 PM
Bigdjs123
If you go back to theri catalog it should say in the desription of the part if it needs flashed
post #8 of 31 Old 04-17-2013, 03:22 PM Thread Starter
ZJNewbi3
It didnt need to be...put it in today and the jeep still doesnt start...so now I have
no voltage at fuel pump
no spark
all relays work
no blown fuses
crank sensor, MAP, and TPS sensors are not getting power nor shorted
cant get CEL readings either
am I missing something here? Only thing I can think of is the PCM ground but I cant find it on my V8. Bout to give up on this thing soon.
ZJNewbi3 is offline
post #9 of 31 Old 04-17-2013, 08:54 PM
ZeeJay1997
The grounds to the PCM are on the passenger side of the block below the head.
ZeeJay1997 is offline
post #10 of 31 Old 04-17-2013, 09:10 PM
tizzly
1994 ZJ
I might have read of the o2 sensor causing something like this. I could be wrong, but its not hard to check the wires to see if they are melted on the exhaust
tizzly is offline
post #11 of 31 Old 04-17-2013, 09:27 PM Thread Starter
ZJNewbi3
Awesome! Where would the wires be? And there are two o2 sensors correct?
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #12 of 31 Old 04-17-2013, 09:44 PM
tizzly
1994 ZJ
1995 should have 1, its located in front of the cat. The wires should lead up over the transmission. Just follow the wires and look for any breaks or burns. Also look for any other wire problems. Again im not for sure its your problem but cant hurt to look. Another possibility is your grounds,.check for loose or rusty conections
tizzly is offline
post #13 of 31 Old 04-17-2013, 10:17 PM Thread Starter
ZJNewbi3
do you know where the grounds are located in a 5.2L V8 because I can only find locations for the 4.0L I6 online unless they are the same? Sorry for all the questions this is my first vehicle and I'm learning steadily. Hope this rain lets up after school tomorrow so I can actually check everything -.-
ZJNewbi3 is offline
post #14 of 31 Old 04-17-2013, 10:36 PM
tizzly
1994 ZJ
They shoukd be the same as the 4.0. Get one of the repair manuals from pep boys or advanced auto, they're full of helpful information
tizzly is offline
post #15 of 31 Old 04-18-2013, 07:59 AM
JS97ZJ
If your going to spend any money on a manual, get a downloadable FSM online.
The paperback toilet paper they sell in part stores are crap. For getting wiring diagrams and other specific info you'll need the factory manual. (10-15 $)
I read some of your previous threads to get some history and you asked about an aux backup light. Did you install it? Where did you hook it up?
You could overload a circuit if it's not on it's own system and blown out a needed fuse for the rest of the vehicle.
The power source for the relays ASD, fuel pump etc. comes from the PCM (5v, 8v). Check the gnds and battery connections like Zee said and recheck all of the fuses.
Here is the PCM connector diagram so you can back probe it with a meter.
JS97ZJ is offline
ecu , no start , pcm
