Replacing Input / Output Speed Sensor on Automatic Transmission - 1999 WJ - MIL P0700 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Replacing Input / Output Speed Sensor on Automatic Transmission - 1999 WJ - MIL P0700
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 10-20-2004, 04:51 PM   #1
Teenkertoy
I hear this is a common problem, so here is a summary of what I did.
Our 1999 Grand Cherokee (WJ) was shifting violently from gear to gear, and the check-engine light came on at the same time. Doing the ignition on-off x3 trick, the instrument cluster spit out the code "P0700". We ran over to our local auto parts store and borrowed an "OBDII" tool and pulled the following codes out of the computer:
P0700
Check Transmission DTC's
This code indicates that the EATX (Transmission controller) has an active fault and has illuminated the MIL via a BUS message. The specific fault must be acquired from the EATX via a DRBIII tool. (Input or Output Speed Sensor failures often cause this code and are a common failure part on WJ Grand Cherokees).
P0715
Input/Turbine Speed Sensor Circuit
P0731
Gear 1 Incorrect Ratio
P0732
Gear 2 Incorrect Ratio
P0734
Gear 4 Incorrect Ratio
I found these translations at WJ Jeeps and the code P0700 had a link to another page titled "Transmission input & output speed sensors".
Now I was pretty sure the input speed sensor was broken because code P0715 indicated the "Input/Turbine Speed Sensor Circuit". We then went to the local dealership (because no one else had the part in stock) and purchased this for $43. Went back home and followed the steps listed on the WJ Jeeps page and 30 minutes later we were finished.
I cleared the fault codes using the OBDII tool, drove around the block a few times and tried to pull the codes again but the tool simply said there were no codes to pull. Very simple, very easy to do...one bolt! I hope this saves you a trip to the mechanic.
~Teenkertoy
Teenkertoy is offline   Reply With Quote
Unread 10-20-2004, 05:01 PM   #2
JoeyJoJo
Thanks for the message! I have a 99 WJ as well and will likely run into this probelm one day. Now I don't have to take it to the dealer!
JoeyJoJo is offline   Reply With Quote
Unread 06-29-2011, 04:42 PM   #3
brianbarker
1990 FSJ Cherokee
would this apply to a 90 cherokee laradeo?
brianbarker is offline   Reply With Quote
