replacing hatch mechanism - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > replacing hatch mechanism
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 07-03-2012, 05:57 PM   #1
nicklopic
so the hatch on my zj is dented from the PO and the inlay where the license plate goes does not sit right which has caused rust at the bottom of the hatch and the entire mechanism
Is it possible to replace the mechanism? I'm sick of trying to fix it only to have it knocked out of place as soon as my subs hit or the road vibrations knock it out that same day.
98' Grand Cherokee 4.0, 3" lift (2" BB and upcountry springs) 32" BFG All-Terrains
Aluminum Rad, Hella 500ff's, Cobra CB, 102" whip, IRO exhaust, Super 40 Magnaflow Cat, Kenwood deck, Kicker DS65 speakers, Sony Xplod amp, Kicker Comp10s in a sealed box
nicklopic is offline   Reply With Quote
Unread 07-03-2012, 07:02 PM   #2
KoreaZJ
1994 ZJ
Open liftgate, pull the inner panel. Latch is easily replaced.
KoreaZJ is offline   Reply With Quote
Unread 07-04-2012, 11:48 AM   #3
nicklopic
where can i get it though? ive tried to find it but all i find is the actuator/key lock
Unread 07-04-2012, 07:51 PM   #4
KoreaZJ
1994 ZJ
Liftgate latch
Mopar part #04883254
Where?
HERE
HERE
HERE
HERE
Unread 07-05-2012, 09:50 AM   #5
nicklopic
i need the mechanism inside, like the rods, and whats right behind the handle
i did use the first link and got this part which is what im looking for, so thank you
the part number is 05017508AA
http://www.moparpartsoverstock.com/p...5017508AA.html
